I have noticed that shortcut locations automatically get substituted in PLP2021, which results in certain command line and other integration tools not working. As an example, the "Using Imagej on Server" protocol does this. If I use temp directories that are not associated with any shortcuts, protocol runs fine. I can also use the same protocol on older PLP builds (2018) successfully. Is there a way to disable replacing shortcut names and always use full file paths? Ideally I don't want to delete all shortcuts as they are useful elsewhere...
