Installing BIOVIA 2021 Applications on Pipeline Pilot 2021 SP1
BIOVIA recently released Pipeline Pilot version 2021 SP1. Pipeline Pilot based applications or application collections like Insight, Insight for Excel, Chemical Registration, Biological Registration, and Solvation Chemistry did not receive an update at that time and therefore are on their original 2021 release level. When installing these original 2021 applications into Pipeline Pilot 2021 SP1 you must follow a slightly modified installation workflow as noted in the Pipeline Pilot 2021 SP1 Product Release Document. Be aware that if you do not follow this modified installation workflow but just ran the native 2021 application installer, it will remove major parts of your Pipeline Pilot 2021 SP1 installation.
Basically, you copy the application installer packages of the 2021 application into the packages directory of the Pipeline Pilot 2021 SP1 installer, and then run the Pipeline Pilot 2021 SP1 installer again (rather than the original 2021 application installer). Accordingly, below refers to the directory into which you unpacked the Pipeline Pilot 2021 SP1 installer files.
On Windows:
1. Extract the .7z archive for the application to a location on the Pipeline Pilot server
2. Copy all .pib files from \\packages\\, except for scitegic_installer.pib, to \\packages\\.
3. Double-click \\bin\\scitegicsetup.exe.
4. When prompted, click Add/Remove Products.
On Linux:
1. Extract the .tgz archive for the application to a location on the Pipeline Pilot server.
2. Copy all .pib files from /packages/, except for scitegic_installer.pib, to /packages/.
3. Run sciinstall.
4. When prompted, choose Add/Remove packages from an existing installation.
