The attached script can be used to convert docked ligand poses in a receptor into a movie/animation.
Usage: unzip the attached file and save to a local directory. From the DS Client, open the results of a ligand docking job. Go the Files Explorer (View > Explorers > Files) navigate to the saved Poses2Images.pl file, right click on the file and select 'Open With | Script Window'. To run the script right click over the script window and choose 'Run'. The output png files will be written to the same location where the script was saved.
DISCLAIMER: This custom script is compatible with Discovery Studio 2020. The code or software provided by Dassault Systemes Biovia Corp. ("BIOVIA") in conjunction with this request is provided under the same license terms and restrictions as the underlying BIOVIA software it is intended to be used with, including license duration and location based restrictions, with the following exceptions. This software is provided on an AS-IS and AS-AVAILABLE basis with no guarantee or warranty, and is not subject to maintenance, updates, or support. When your license to use the underlying BIOVIA software terminates, your license to use this software will also terminate. BIOVIA makes no warranty that this software will be usable for any purpose.
