The Register Another workflow, available in both Biological and Chemical Registration enables you to very rapidly register a new lot of an existing biological or chemical substance without needing to repopulate key attributes again.
When picking the Register Another workflow, key attribute values are automatically copied from an existing lot to a new lot record in a single click. You can then populate any additional attributes before registering the lot. Prior to the 2021 release of Registration, any file attachments associated to the existing lot record were not automatically copied over, resulting in you needing to locate and then attach these files again. In the 2021 release we have updated the workflow so that existing file attachments are now copied over automatically, enabling you to avoid having to do this manually for yourself ever time you want to register another lot. The attached video shows the updated workflow in action.
