PURPOSE: To quickly build peptide structures given multiple sequences (in fasta format).
This example illustrates how to build peptide structures from sequences. This is not intended for building large protein structures. One should use the Build Homology Models protocol in Discovery Studio to build proteins.
The input is a fasta file with multiple peptide sequences and the output will be a separate dsv file for each structure.
USAGE: This protocol can be launched from both the Discovery Studio and Pipeline Pilot clients. To install in Discovery Studio only, go to the Protocol Explorer, right-click over the folder you want to add the protocol to, choose Import, navigate to the location of the Build Peptides.ppxml file and enter it as the File Name.
REQUIREMENTS: Discovery Studio Embedded Collection.
DISCLAIMER: This custom script is compatible with Discovery Studio 2022. The code or software provided by Dassault Systemes Biovia Corp. ("BIOVIA") in conjunction with this request is provided under the same license terms and restrictions as the underlying BIOVIA software it is intended to be used with, including license duration and location based restrictions, with the following exceptions. This software is provided on an AS-IS and AS-AVAILABLE basis with no guarantee or warranty, and is not subject to maintenance, updates, or support. When your license to use the underlying BIOVIA software terminates, your license to use this software will also terminate. BIOVIA makes no warranty that this software will be usable for any purpose.
