The attached protocol can be used to convert ZDOCK poses into conformations.
Usage: Simply unzip the attached file and then from the Discovery Studio Protocols Explorer (View > Explorers > Protocols) right-click over your User folder and choose Import and navigate to the unzipped .ppxml file. You might need to right-click over your User folder and choose Refresh but then you will see this new protocol.
DISCLAIMER: This custom protocol is compatible with Discovery Studio 2020. The code or software provided by Dassault Systemes Biovia Corp. ("BIOVIA") in conjunction with this request is provided under the same license terms and restrictions as the underlying BIOVIA software it is intended to be used with, including license duration and location based restrictions, with the following exceptions. This software is provided on an AS-IS and AS-AVAILABLE basis with no guarantee or warranty, and is not subject to maintenance, updates, or support. When your license to use the underlying BIOVIA software terminates, your license to use this software will also terminate. BIOVIA makes no warranty that this software will be usable for any purpose.
