Dear all,
Please find attached the list of all fixed issues on R2018x FD01 level.
You can find details about each of this BUG Report by searching directly its reference in the KB.
| BR | ABSTRACT |
| click here | When we click on left button , the Globe Viewer zoom-out is not sending any intercom event which indicates this action. |
| click here | Administrative user receiving unjustified "license expiration" notification |
| click here | In the 3DEXPERIENCE Simulia Physics Results Explorer app, it is not possible to pick a node for creating display group if a min/max label is active on the node. |
| click here | 6W Tagger: Not able to add new tags to a task |
| click here | 3DExperience Simulation Companion could not directly launch Isight gateway using OS command. |
| click here | In Abaqus/Standard, a contour integral evaluation analysis that specifies an element set for the contour integral domain using *CONTOUR INTEGRAL, ELSET=yyy aborts in the solver input file processor when the elements are not numbered continuously. |
| click here | On IOS,input text are no longer taken into account after you swipe a little bit outside while typing. |
| click here | In UIKIT framework,an update of the value using the arrows (up and down) does not trigger an onChange event (on the contrary of a change of the value directly with the keyboard). |
| click here | Unable to synchronize an empty pointer |
| click here | Issue with the monitoring Window Display |
| click here | Export paly as DXF will not work if there is no ISO.xml standard file in the directory |
| click here | Weight distribution in BI Essentials shows incorrect results. |
| click here | 3DX crashes when updating material database |
| click here | CATIA Part Design: Smooth edge with applying Gouraud shading is different between R2017x and CATIA V5 or R2016x. |
| click here | Not possible to modify a pipe after duplicate |
| click here | When using "new reference" for placing Piping parts, the number of times a new reference can be made is limited to 4. Once a new reference is made for the fifth time the part behaves like "reuse reference" with no notification to the user. |
| click here | Piping & Tubing Design: The size of center line for pipe creation is changed depending on zoom in/out. |
| click here | Piping & Tubing Design: Directional Length is not conserved when creating route pipe. |
| click here | Piping & Tubing 3D Design: Route Pipe Length is not modified properly |
| click here | Piping & Tubing 3D Design: Port is not detected on standard 3DPart while creating Route. |
| click here | Value of Attribute of Pipe is changed , after creating Route. |
| click here | Commenting on files is blocked on 3ddrive |
| click here | Minor revise is not supported on Physical Product from Change Action on Rich Client. |
| click here | Tasks for change action disappear |
| click here | Versioning of a Resolved Part doesn't take into account the Phantom status |
| click here | Cannot replace the last version of EBOM structure for differents effectivties |
| click here | The 3DEXPERIENCE Structural Model Creation app does not allow users to modify the support of the simulation connections in the model imported from the CATIA V5 analysis file. |
| click here | In the 3DEXPERIENCE Simulia Structural Model Creation App, when the point mass is applied to two or more vertices, the Nastran input file is generated incorrectly. |
| click here | An Abaqus/Standard *FREQUENCY procedure including *TIE, CYCLIC SYMMETRY and *DISTRIBUTING fails abnormally with an error message. |
| click here | Spaces and Line Spacing is Not retained when Editing front for Comments by keyboard |
| click here | In 3DDashboard , sentence is correctly displayed in 'About 3DEXPERIENCE Platform' but it is incorrect in 3DSwym |
| click here | Restricted visibility Risk is visible to project members who should not be able to see it |
| click here | Path Planner pannel not launched from PPR with Review top node |
| click here | Tool Assembly dimension values are wrong in 3D display when in INCH mode |
| click here | No way to instantiate a resource derived from MfgUserDefinedTool |
| click here | Machining: issues with MFG_Name when importing tools from csv file |
| click here | If do not add content in Route Wizard, the notice by mail is not displayed correctly. |
| click here | Project Mgt, The search object to "Applies to" Decision shows federated search error. |
| click here | After customizing search columns to include "Design Number" attribute (see video: how to customize search columns), I am not seeing the values of this attribute in my search results. |
| click here | When the language set Simple-Chinese, user name should be displayed as the last name is in front, the name is last" |
| click here | Functional Generative Design : with Parametric Optimization Optimiszation the parametric cannot be reoppened |
| click here | After exapnding 3DPLAY content in full screen mode, page become blank |
| click here | Usage of non Roman Character displays bad User Initials. |
| click here | In Globe Viewer widget , Zoom-in & Zoom-out InterCom events is not distinguished . |
| click here | Installation troube for Microsoft for collaboration |
| click here | 3DXCity: When opening drag and drop City Referential App error occur. |
| click here | 3DXCity: Creating of City Referential Datasets failed |
| click here | Attribute Groups do not get created in Platform Management / Attribute Management |
| click here | 3DExperience DSLS license Statistics tab selections are partially hidden making it hard to view / recognize the filter selections. |
| click here | LAT windows not scrolling |
| click here | CATBatchStarter error with license error when executing from command window |
| click here | Cant delete object in Collaboration lifecycle in 3DDashboard |
| click here | Only root node is duplicated with Duplicate command if extended attributes are displayed in tree |
| click here | RFLP/Import: Not able to import existing logical object under different logical reference |
| click here | Abaqus/Explicit analyses using VUMAT having no state variables generate diagnostic messages with typos |
| click here | 3DXCity: City Discover and City Referential Widgets show 'You do not have access to this widget' message |
| click here | Apparel online documentation help pages reference wrong functionalities in some cases |
| click here | Missing apps in preferences -> customize 17x |
| click here | Tab Switching - unable to switch tab properly |
| click here | "Has EBOM connected" and "Is top part" are always blank is search results |
| click here | The Color of 3D Shape is not changed during B.I.Essentials Activated in Authoring Mode. |
| click here | Task Reference Document in template is not carried over to project |
| click here | Project Management - Scheduling - Assignment Task View error |
| click here | Collab Task: After removing the context, Collab Task still shows the project task |
| click here | In Collab Task Widget comments added to task get disappeared |
| click here | HW Product revision from Product Line Hierarchy page does not work correctly |
| click here | 3Dsearch display error in Chinese language |
| click here | In the 3DEXPERIENCE Structural Scenario Creation App, for certain load types, the robot coordinate system does not display the local axes. |
| click here | 3DEXPERIENCE Process Composer Experience: The Instantiation Options of an empty Experience issues an Internal Server Error message. |
| click here | unable to import a PLN in perfect Shelf CLOUD |
| click here | Numbering error and detection numbers error in book merchandising |
| click here | In My Communities of 3DSwym , List of top 10 community is not updated and you don't see last community selected . |
| click here | On the Linux platform, an optimization analysis in Tosca Structure aborts with an error message when the environment variable 'LANG' is set to 'C'. |
| click here | The Tosca Structure GUI does not allow the user to add 'CYCLE_COMPLETE' parameter used to define the checkpoint rule for the driver-objects 'registerSaveRule' and 'registerCheckPointHook' that are used in the DRIVER keyword block of a *.par file. |
| click here | INFRA_3309 - Rerun Transfers fails during RepMigration |
| click here | Files located on disk are not availbe during coexistence import from SmarTeam. |
| click here | Attribute's import fails in Functional and Logical Design |
| click here | Search icon of 'Context : My Tasks' in collaborative task widget is not working when widget is opened in reduced size in dashboard. |
| click here | Cannot change comment of other user for a task in widget |
| click here | The Physics Results Explorer app aborts when trying to manipulate an XY plot containing millions of increments |
