Tutorials: Composites Design & Simulation
Are you interested in Composite Design?
Then this list of Tutorials is a must watch for you.
Index:
  1. 3DEXPERIENCE | Introduction to Composites
  2. CATIA 3DEXPERIENCE | Composites Design - Manual Approach Design
  3. CATIA 3DEXPERIENCE | Composites Design - Grid Approach with Import
  4. CATIA 3DEXPERIENCE | Composites Design - Grid Approach Design
  5. CATIA 3DEXPERIENCE | Composites Design - Solid Slicing Approach Design
  6. SIMULIA 3DEXPERIENCE | Composites Simulation
In this tutorial, viewers will learn some fundamental elements of composites materials theory (definitions, vocabulary), design and manufacturability of composites, and gain knowledge about the applications for composites design available on the 3DEXPERIENCE platform.
Chapters:
00:30 Basics of Composites
5:50 Composites in the 3DEXPERIENCE Platform
10:15 Composites Design
12:00 Manufacturability
14:50 Conclusion
In this tutorial, users will acquires some knowledge about the Manual Approach Design method on CATIA 3DEXPERIENCE. The Manual Design approach is the simplest approach within 3DEXPERIENCE Composites. For this approach, the user defines each ply manually using contours and support surface.
Chapters:
01:05 Login to 3DEXPERIENCE and Prepare the Environment
02:05 Define Composites Parameters
06:55 Create Plies Group & Plies
09:45 View Plies Sections & Modify Plies Geometry
13:30 Manage Plies
19:25 Conclusion
In this tutorial, users will acquires knowledge about the Grid Approach with Import method on CATIA 3DEXPERIENCE. This approach allows the user to import the data required to define plies directly from a spreadsheet.
Chapters:
02:10 Login to 3DEXPERIENCE and Prepare the Environment
04:50 Define Composites Parameters
09:15 Create a Grid Panel
11:45 Import Composites Design Data using a Spreadsheet
13:50 Conclusion
In this tutorial, users will learn about the Grid Approach Design method on CATIA 3DEXPERIENCE. This method allows users to design in the context of an assembly by referencing interfacing structural elements to help integrate the design and analysis process. With this method, the user will define a grid panel, create a grid, specify a virtual stacking, and generate plies from the virtual stacking.
Chapters:
01:45 Login to 3DEXPERIENCE and Prepare the Environment
03:20 Define a Grid Panel
06:40 Create a Grid
10:25 Set a Virtual Stacking
14:05 Generate Plies from the Virtual Stacking
17:50 Conclusion
In this tutorial, users will learn about the Solid Slicing Approach Design method on CATIA 3DEXPERIENCE. Using this method, the user can slice the associated solid that is created using the zones for creating plies. This method consists of two sub-steps: slice the associated solid created from the zones to create the slicing curves, and create the plies using the slicing curves.
Chapters:
01:25 Login to 3DEXPERIENCE and Prepare the Environment
03:00 Create a Zone Group
04:30 Define a Zone
06:25 Define Slicing Group
09:25 Generate Plies from Slicing Group
10:00 Conclusion
In this tutorial, users will learn how to perform a finite element simulation on a composite part on SIMULIA 3DEXPERIENCE. By the end of this tutorial, the user will be able to set up a simulation, insert step, boundary conditions, and load, define simulation outputs, and finally, perform a results analysis.
Chapters:
00:45 Login to 3DEXPERIENCE and Prepare the Environment
01:55 Set Up a Simulation
05:15 Insert Step, Boundary Conditions and Loads
06:45 Define Simulation Outputs
09:50 Results Analysis
13:05 Conclusion
About 3DEXPERIENCE Edu:
Dassault Systèmes Academic: https://edu.3ds.com/
Dassault Systèmes Trainings - Edu Space: https://eduspace.3ds.com/
3DEXPERIENCE Edu Students community: https://go.3ds.com/studentcommunity
3DEXPERIENCE Edu Academics community: https://go.3ds.com/academiccommunity
EDU YouTube Channel: https://www.youtube.com/c/3DEXPERIENCEEdu
Follow us on:
Twitter: https://twitter.com/3DXEdu
Instagram: https://www.instagram.com/3dxedu/
