TEAM NAME : THE PRODIGY
PITCH:
The product which we worked on is a Savonius wind turbine. It is a vertical-axis wind turbine (VAWT) type vertical-axis wind turbine (VAWT), used to convert the wind's forcewind into torque on a rotating shaft. The turbine consists of a number of aerofoils, usually—but not always—vertically mounted on a rotating shaft or framework, either ground stationed or tethered in airborne systems.
this type of wind mills could be set on road sides to generate electricity which is enough to power the streen lights. this model works in such a way that the air and the force of the vehicals can be able to rotate the turbine.
we made the cad model by reffering the Wikipedia and youtube
All the resources and information is collected from Wikipedia and the existing product explenation created by kerem deveci (traffic turbine ) to explain the model
Edu Take Climate Action
https://www.youtube.com/watch?v=1nqp09nFQZA
