# Take Climate Action : The Dominators
Team Name: Dominators (Shivam Khandekar)
Pitch:
Increasing carbon emissions is hazardous to humans mankind. For short distance traveling also we use bikes so that it affects in increasing pollution. Now we want current bicycles converted to E-bicycle in a simple, feasible, and affordable manner to give comfortable traveling that is why people will start to use bicycles.
As to Take Climate Action & To decrease pollution bicycle is the best option. But it's difficult to pedal and makes a ride more discomfort than a bike ride because of this fact and mentality people try to avoid the use of bicycles to travel. So, we want to convert normal bicycles to electric bicycles with a simple conversion kit. So, we create a small box containing solar panels with a controller and battery system. This kit reduces the complex connection of the controller with various components we provide some slots on the box so it will work like we use a component then plug in it and use a component(like headlight, horn, anti-thief sensors, controlling connections also.)
Describe the positive impact created by your solution in society.
People start to use electric bicycles
Help to reduce the temperature
Increases electricity generation and reduces dependency on grid energy
Cycling good impact on the Health of people
If everyone start does adapt e- bikes there will be a huge reduction in Carbon Emission.
How to use:- 1)We have to just hold the hole kit with Bicycle Side rods with holders parallel to the wheel as shown in the pic.
2) There are various slots provided for the other components like Motor Hub,
Key locker, throttle to increase race, Pedal assists, etc to connect with the controlling system of the kit. (It simplifies complex connection-making).
3)By using a USB port you also charge the lithium-ion battery with grid electricity. Also, there is a solar Panel (which is open and closed like an origami fan) that continuously charges the batteries.
4) About these panels, these should be open when bicycles are in a steady state they are Perovskite solar panels (10-25% more Efficient, Can be printed in any shape, and 2-5mm in thickness)
Edu ​​​​​​​Take Climate Action ​​​​​​​
