Team work : I work individually
Pitch of the project :
Currently the major problem in automobile industry is air pollution with effect the climate change & global warming. So, we invented HHO generator which will reduce approximately 70% of pollution then other fuel which are available in market.
we found that the biggest problem with hydrogen is the storage. so we overcome with the solution, we will produce hydrogen according to need. so their will be no storage issue. this is the research paper of generator.
How does a hydrogen generator work?
A hydrogen generator works by using electricity to split the hydrogen atoms in a water molecule apart form the oxygen atom. This is done by a process called electrolysis, and is performed in a cell inside the hydrogen generator. The cell contains an anodic catalyst and a cathodic catalyst separated by a proton exchange membrane. Hydrogen ions are attracted to the cathodic catalyst, while the oxygen ions are attracted to the anodic catalyst. The pressure of hydrogen gas is then allowed to build to the desired pressure and delivered to the end user.
Software : Solidworks.
Take Climate Action Edu
