Boost your SolidWorks productivity with these practical tips and tricks.
🔧 General Productivity Tips
Keyboard Shortcuts
- Master the
Skey shortcut bar — it changes based on your environment (sketch, part, assembly, or drawing). - Create custom shortcuts for your top commands:
Tools > Customize > Keyboard. - Pro tip:
Ctrl + Tab→ switch between open documents.Ctrl + 1-8→ activate standard views.
- Master the
Shortcut Bar (
SKey)- Right-click it to customize for each environment.
- Add frequent commands like Measure, Section View, or Hide/Show.
Mouse Gestures
- Hold right-click and drag (4 or 8 directions) to activate commands.
Customize via
Tools > Customize > Mouse Gestures.
📐 Sketching Tips
🖼️ Fully Defined vs Underdefined Sketch
VS
Convert Entities & Offset Entities
- Convert Entities generates sketch edges from model edges.
- Offset Entities creates consistent borders or clearances.
Fully Define Sketches
- Black = fully defined, blue = underdefined.
- Use
Tools > Sketch Settings > Automatic Relations. - Use the "Fully Define Sketch" tool for fast constraint application.
Construction Geometry
- Convert sketch elements with
Ctrl + Click→ Construction Geometry. - Use centerlines for symmetry and rotation references.
