Sheet Metal Panel Fabrication
Design: The first step in sheet metal panel fabrication is to create a design that includes the specifications for the panel's size, shape, and material.
Cutting: The next step is to cut the sheet metal to the desired size and shape using techniques such as laser cutting, water jet cutting, or die cutting.
Bending: Once the sheet metal is cut, it is bent into the desired shape using a press brake or other bending equipment.
Welding: The bent sheet metal is then welded together to form the panel. This may be done using techniques such as MIG welding, TIG welding, or spot welding, depending on the type of metal and the panel's design requirements.
Finishing: The panel is then given a final finish, such as painting, powder coating, or anodizing, to protect it from corrosion and to improve its appearance.
Testing and inspection: The finished panel is then tested and inspected to ensure that it meets all the specifications and requirements, and any necessary modifications are made.
Delivery: Finally, the panel is packaged and delivered to the customer for installation and use.
Sheet metal panel fabrication is a cost-effective and efficient method of creating metal panels for various applications, including construction, electrical and mechanical systems, and many other industries.
Edu ​​​​​​​
