MATERIAL MODELS: Anisotropic materials
This post is a continuation of the Getting Started with Abaqus series
Anisotropic Material Modelling for Finite Element Analysis (FEA)
👉 In FEA, material modelling plays a crucial role in accurately simulating the behavior of a structure under various loading conditions. When dealing with materials that exhibit different mechanical properties in different directions, anisotropic material modelling becomes essential.
Isotropy vs. Anisotropy
👉Isotropic Material: These materials exhibit the same mechanical properties (elasticity, strength, etc.) regardless of the direction of applied stress or strain. Common examples include “simplified” models of steel, aluminum, or some types of plastic in their elastic range.
👉Anisotropic Material: These materials have properties that vary depending on the direction. Examples include wood, composite materials, rolled metals, and bones.
Modelling Anisotropic Materials
There are several approaches to model anisotropic materials in FEA, each with varying levels of complexity and suitability depending on the material and analysis requirements. Here's an overview of common methods:
➡️Engineering Constants Approach:
This method utilizes a set of material constants specific to the anisotropic behavior. These constants can be obtained from experimental testing or material data sheets.
Common constants used include:
  1. Elastic Moduli (): Young's modulus in different directions (e.g., )
  2. Poisson's Ratios (v): Ratio of transverse strain to axial strain, with multiple values depending on the direction of loading (e.g., , etc.)
  3. Shear Moduli (): Resistance to deformation under shear stress, with multiple values for different planes (e.g., , , etc.) This approach is relatively simple to implement but may not capture complex anisotropy behavior.
Material Direction Definition:
  • This method defines a material coordinate system (MCS) within the element. The material properties are then specified relative to this MCS.
  • This allows for accurate representation of the material's directional dependence of properties.
  • It's crucial to ensure proper alignment of the MCS with the actual material grain direction or fiber orientation for accurate results.
👉Transversely Isotropic Material:
A special case of anisotropy where the material exhibits the same properties in all directions within a specific plane (often the xy-plane).
This can be modelled using a reduced set of material constants compared to the full anisotropic approach.
Applicable to materials like wood or rolled sheet metal with a dominant grain direction.
Advanced Material Models:
For highly complex anisotropic materials, more sophisticated models might be required. These models can incorporate factors like:
  • Non-linear material behavior (plasticity, damage)
  • Strain rate dependence
  • Material microstructure
These models often involve user-defined material subroutines within Abaqus and require in-depth understanding of material behavior and advanced FEA knowledge.
All of Hooke’s law strain–stress relationships can be concisely written in matrix form. For a general anisotropic (directionally dependent) material, with initial thermal strains, the matrix form is
Where the “compliance matrix” relates the stresses to the strains.
🤔Creating a brand-new material? Here's how:
  1. Gather Data: We start by collecting multiple sets of experimental data on the material's behavior. This data needs to fit the rules set by a certain equation (already mentioned).
  2. Data Wrangling: The collected data might not be perfectly formatted for our needs. We need to adjust it to ensure the "compliance matrix" (a mathematical tool used to describe material properties) is both symmetrical (same values on opposite sides of the diagonal) and positive definite (all diagonal values are positive).
  3. Extracting Material Properties: Once the data is prepped, we use a numerical technique (like matrix inversion) to extract the specific elasticity matrix (another mathematical tool describing material stiffness) for this unique material.
Considerations for Anisotropic Material Modelling
Material Characterization: Accurate and relevant material data is essential for successful implementation of any anisotropic material model. This might involve conducting specialized material testing or obtaining reliable data from reputable sources.
Computational Cost: Compared to isotropic models, anisotropic models can increase computational complexity and simulation time. Choosing the appropriate level of complexity for your analysis is crucial for balancing accuracy and efficiency.
For the most general anisotropic material, both the elasticity matrix, E, and the compliance matrix, E, are completely full matrices. It should be noted for incompressible materials, with , the above classical theory gives division by zero! In that case, an advanced constitutive law that includes the hydrostatic pressure,
must be utilized; or advanced finite element numerical tricks (like reduced integration) must be employed to get correct results. Likewise, if a man-made material has , then that causes negative stiffnesses, and advanced material theories and/or numerical tricks must again be invoked to get correct answers.
➡️Benefits of Anisotropic Material Modelling⬅️
  1. Improved Accuracy: By capturing the directional dependence of material properties, anisotropic models can provide more realistic and accurate predictions of stress, strain, and deformation behavior in structures.
  2. Optimized Design: Understanding the true anisotropic behavior of materials allows engineers to design structures that are more efficient and meet specific performance requirements under various loading conditions.
  3. Material Selection: FEA simulations with anisotropic models can help engineers select the most suitable material for a specific application, considering its directional properties and impact on overall structural performance.
Conclusion:
Overall, anisotropic material modelling is a valuable tool in FEA for analyzing structures made from materials that exhibit directional dependence in their mechanical properties. By understanding the different modelling approaches, their limitations, and the importance of accurate material data, engineers can leverage FEA to achieve more accurate and reliable simulations for various engineering applications.
