Create a part in the form of Letter A using Python script.
The script does the following:
Creates a new model in the model database.
Creates a two-dimensional sketch.
Creates a three-dimensional, deformable part.
Extrudes the two-dimensional sketch to create the first geometric feature of the part.
Creates a new viewport.
Displays a shaded image of the new part in the new viewport.
To run the program, do the following:
Start ABAQUS/CAE by typing ABAQUS cae.
From the startup screen, select Run Script .
From the Run Script dialog box that appears, select LetterA.py (or any name you chose)
Click OK to run the script.
<span class="marker mark-green">#import modules and create a part in the mdb object</span>
from abaqus import *
from abaqusConstants import *
backwardCompatibility.setValues(includeDeprecated=True,
reportDeprecated=False)
import sketch
import part
myModel = mdb.Model(name='Model A')
mySketch = myModel.ConstrainedSketch(name='Sketch A',
sheetSize=200.0)
xyCoordsInner = ((-5 , 20), (5, 20), (15, 0),
(-15, 0), (-5, 20))
xyCoordsOuter = ((-10, 30), (10, 30), (40, -30),
(30, -30), (20, -10), (-20, -10),
(-30, -30), (-40, -30), (-10, 30))
for i in range(len(xyCoordsInner)-1):
mySketch.Line(point1=xyCoordsInner[i],
point2=xyCoordsInner[i+1])
for i in range(len(xyCoordsOuter)-1):
mySketch.Line(point1=xyCoordsOuter[i],
point2=xyCoordsOuter[i+1])
myPart = myModel.Part(name='Part A', dimensionality=THREE_D,
type=DEFORMABLE_BODY)
myPart.BaseSolidExtrude(sketch=mySketch, depth=20.0)
<span class="marker mark-green">#Create a part and add a base feature using the sketch</span>
<span class="marker mark-green">#Plot themeshed instance in a new viewport</span>
myViewport = session.Viewport(name='Viewport for Model A', origins=(20,20), width=150, height=100)
myViewPort.assemblyDisplay.setValues(renderStyle=SHADED, mesh=ON)
myViewport.setValues(displayedObject=myAssembly)
