IMPLEMENT RELATIONS AND TRACEABILITY STUDIES
SystemsEngineering Tips&Tricks CATIAFunctional&LogicalDesign Edu  Community Knowledge
Previous Post
Introduction
Implement links are used to connect objects from the four RFLP tree categories (Requirement, Functional, Logical, Physical).
An implement link:
  • Identifies the purpose of the implementing object
  • Defines the context to be loaded when opening with completion an object (in case of a reference-reference implement link)
  • Implement Links Display
  • Context and Subcontext Definition
  • Implement Links Between Objects
  • Implement Links List
  • Implement Links: Display in the 2D Graph
Implements links are displayed in the tree (in the implementing object node) and in the work area (on both implemented and implementing objects).
Tips:
  • In the tree, click the implement link to highlight the implementing and implementing objects.
  • In the work area, click the icon to display the implementing or implemented object.
Implemented Icon
Implementing Icon
In the tree, if the corresponding options are selected, the implement relations are stored in these folders:
  • Implement Relations: The two entities pointed by the implement relation are present in session.
  • Partially Loaded Implement Relations: At least one entity pointed by the implement relation is not present in session (but both extremities exist).
  • Broken Implement Relations: At least one entity pointed by the implement relation no longer exists.
Between two references, links can be defined in the context or subcontext of the selected references.
Between two categories, whatever element you first select when creating an implement link, the implement relation is always created from the lower level abstract category to the higher level abstract category.
In other words:
  • A physical product implements a function, a logical component or a requirement.
  • A logical component implements a function or a requirement.
  • A function implements a requirement.
 Implemented Requirements
You can create an implement link between the following elements:
Implemented Functional Objects
(SAVE OR USE ZOOM TO VIEW THE IMAGE)
Implements Link List
To list implement relations on an object, you can use:
  • The RFLP Linked Objects panel
  • The Traceability Matrix
  • B.I. Essentials
Traceability Matrix
The Traceability Matrix displays the implement relations existing between two structures. You can create, edit or delete implement relations between these two structures in this editor.
You can display implement relations between objects from the following categories:
  • Requirement and Functional/Logical/Physical
  • Functional and Requirement/Logical/Physical
  • Logical and Requirement/Functional/Physical
  • Physical and Requirement/Functional/Logical
The occurrence-occurrence links created in subcontext are visible in Traceability Matrix.
BI Essentials
You can use B.I. Essentials to reveal attributes of the objects in your session. Color codes corresponding to the different values of an attribute are applied to the objects. B.I. Essentials specific to Functional & Logical Design enables you to display information on functional and logical objects.
Related Resources
Getting Started with Systems Engineering Series
This video series will help you to get started with System Engineering using the 3DEXPERIENCE Platform
Topics Covered:
  • Introduction to Systems Engineering
  • Introduction to Modelica and Dymola Behavior Modeling
  • Setting up your Environment
  • Creating Requirements, Functions, Logic, and Physical
  • Behavior Modeling and Simulation
  • Implementing Relations and Traceability
3DEXPERIENCE ​​​​​​​ CATIA ​​​​​​​ Dymola Behavior Modeling ​​​​​​​
