How SOLIDWORKS MBD Helps Engineers Work Faster!!
🚀 What is SOLIDWORKS MBD? 🚀
SOLIDWORKS Model-Based Definition (MBD) helps you add dimensions, tolerances, and other manufacturing details directly on the 3D model, eliminating the need for separate 2D drawings.
🎯 Why Use MBD?
✅ Go Paperless! No need for 2D drawings – everything is in 3D.
✅ Fewer Mistakes – Clear and direct communication.
✅ Easy to Share – Create interactive 3D PDFs.
✅ Faster Manufacturing – No confusion, just action!
🔍 How Is It Different from 2D Drawings?
Instead of looking at flat drawings, manufacturers can rotate, zoom, and inspect the actual 3D model with all details in one place.
📸 Check out these images of my model with MBD applied!
☝️ You can add tables, geometric tolerances, and flat patterns (for sheet metal) just like in 2D drafting.
☝️ You can also add datums, general dimensions, and GD&T annotations directly in 3D.
🎥 Watch this short video to see how MBD works in SOLIDWORKS!
📂 Paperless & Interactive – 3D PDF Templates!
You can also create a 3D PDF template of your model! This lets others rotate, zoom, and inspect the 3D model with all dimensions and annotations inside a PDF—no CAD software needed!
👉 You can also check out my last post for more insights on compliant mechanisms and their benefits.
