Behind the scenes....
Reverse engineering via structured light 3D Scanner which helps in removing unwanted design artifacts, eliminating any errors in the model & resolving foreign key references!
Some iterations were noticed altering the position of object while few post-processing would get the work done at end:))
I will use the the 3DEXPERIENCE Reverse Engineer role to Import and refine the digitized data & post the part later.
Edu ​​​​​​​3DEXPERIENCE Reverse Engineering ​​​​​​​Work Showcase
