Axial Fan
An axial fan, also known as a propeller fan, is a type of mechanical fan commonly used to move air or gases in a straight-line path through an axial direction. These fans are designed with blades that rotate around an axis, similar to the way an airplane's propeller functions. Axial fans are widely used in various applications, including industrial processes, HVAC systems, electronics cooling, and ventilation.
Working Principle:
  • Axial fans generate airflow by drawing air in parallel to the axis of rotation and then expelling it in the same direction.
  • The blades create a pressure difference between the inlet and outlet, causing air to move through the fan.
Applications:
  • HVAC Systems: Axial fans are commonly used in heating, ventilation, and air conditioning systems for cooling or ventilation purposes.
  • Industrial Ventilation: They are used in industrial settings to exhaust hot air, fumes, or contaminants from manufacturing processes.
  • Electronics Cooling: Axial fans help dissipate heat from electronic components and systems, such as computers and servers.
  • Automotive Cooling: In vehicles, axial fans are used to cool the radiator and maintain the engine's operating temperature.
  • Aerospace: They are used in aircraft engines and ventilation systems.
Edu ​​​​​​​xDesign ​​​​​​​
