Assign weight to an object in the 3DEXPERIENCE platform
In the project IAR80 Fly Again , the P&W 1830 engine exists as a scanned 3D object. To achieve a more accurate weight estimation for the entire aircraft, we need to assign a weight value to this subassembly.
This will be done using B.I.Essentials tool to declare the weight.
You can easily edit the immersive table; the changes will be automatically updated in the Measure Inertia tool. Just make sure to check the 'Consider declared weights and inertia' option
You may also choose to enter a pre-measured center of gravity, as we did. By default, the software calculates this based on your settings. To adjust the CoG coordinates, you can follow the same steps used for modifying the mass.
Edu  3DEXPERIENCE CATIA
