Aircondition Heat Exchanger
 I wanted to design the heat exchanger system, which is the subject of "Heat Transfer", one of my favorite courses in mechanical engineering. To give information about the heat exchanger, it is basically a tool that provides heat transfer between two fluids. The distinguishing feature of the heat exchanger is that it carries out the heat transfer between these two fluids in liquid or gaseous state by preventing the mixing of materials. Plates or other heat transfer surfaces, which are generally used in heat exchangers, both separate the fluids from each other and provide the transfer of heat from one fluid to another. This heat exchange can be heating, cooling or simultaneously bidirectional.
 In this design, I designed the fasteners with xDesign and the plates with xSheetMetal. Being able to switch between these two programs has made my work quite fluid.
Edu ​​​​​​​xDesign ​​​​​​​xSheetMetal ​​​​​​​
