ELECTRICAL METER (20 Feb 1894)
The model shows a cylindrical electrical device enclosed within a smooth outer housing, with internal straight conducting rods mounted along the length of the cylinder. These conductors are supported at both ends by end fittings that also act as electrical terminals, allowing the device to be connected directly into a circuit. The transparent view highlights the internal alignment and spacing of the rods, indicating a controlled and symmetrical construction intended to maintain stable electrical behavior. The enclosure protects the internal elements while still allowing the functional arrangement to be clearly observed.
The arrangement shows a cylindrical electrical device connected directly into an external electrical circuit. The device is placed in series with the wiring and resistive elements, forming a continuous electrical path. The resistors positioned along the circuit regulate the current flowing through the system, while the switch allows the electrical connection to be opened or closed during operation. This configuration demonstrates how the device functions as part of a complete electrical loop, maintaining controlled current flow and stable operation within the system.
The internal arrangement reveals straight conducting elements aligned along the length of the cylindrical structure. These conductors are supported at both ends by terminal fittings, ensuring proper spacing and secure electrical connections. Their symmetrical alignment indicates a controlled internal layout designed to allow current to pass uniformly through the device. The enclosure provides protection and maintains the stability of the internal elements while allowing their functional relationship to be clearly understood.
Overall, the arrangement presents a clear and practical representation of a cylindrical electrical device operating within a controlled electrical circuit. The combination of a stable internal layout and a regulated external connection highlights the simplicity and reliability of the design. This integrated approach supports consistent operation while maintaining clarity in both structure and function.
A 3DEXCITE simulation showcasing the dynamic flow of current through an electrical circuit. By animating the current path, the design becomes more intuitive for technical demonstration and engineering education.
