COVID-19 Rapid Manufacture Ventilator BVM Ambubag for £80 OpenVent-Bristol
Hi, I published my design last night. I'm keen to see people's thoughts: Click here to see design details
Why :
NHS Rapidly manufactured ventilator system specification: https://www.gov.uk/government/publications/coronav...
The USP of this design is how easy and fast it can scale for mass production for the following reasons:
  • Automated production: The production of each part is fully automated (laser cutting), with only 8 different parts
  • Only 6 off-the-shelf components: Very few different components are needed and no exotic parts are needed (not even a motor coupling)
  • Simple mechanism: It uses a super simple mechanism with just an arm mounted to a motor - no complicated mechanisms to go wrong, just one moving part
  • Fast assembly: Complete assembly is possible in around 20 min with one person
  • Adjustable settings: Has full adjustment of breath frequency and pressure/tidal volume and with a small adaption can function within all NHS requirements
  • Low cost
WHO : Credits
Credit to the people below for helping to make this all possible:
  • Sam Reilly - Software Certification Engineer
  • Sadie - ITU nurse
  • Tom Breddal
  • Consultant Anesthetist in UK ITU
WHAT : ​​​​​​​
DXF files and STEP file of the assembly are available here :
Laser cut the following part files from 8mm acrylic or ply with the following quantities:
  • Q1x "Back plate.dxf"
  • Q1x "Left side big hole.dxf"
  • Q1x "Base plate.dxf"
  • Q1x "Arduino DJ shield cover V2.dxf"
  • Q1x "right side small hole.dxf"
  • Q4x "arm contact ring 25mm.dxf"
  • Q2x "Base fins"
To assemble you will need:
  • 9x M6x25mm bolts
  • 4x M6x15mm bolts
  • 14x M6 nuts
STL File :
Video description
WHO :
Darren Lewis
Licence :
Attribution-NonCommercial-ShareAlike
CC BY-NC-SA
Except where otherwise noted, content on this repository is licenced under a Attribution-NonCommercial-ShareAlike 4.0 International (CC BY-NC-SA 4.0) Licence.
