Revise Your Design and Add Features
Learn how to open a part from the 3DEXPERIENCE platform, create a pattern feature, and save it as a new revision
What's Covered?
- Editing an Existing Design: How to open a previously saved design, specifically a pair of needlenose pliers, from the 3DEXPERIENCE platform and make modifications [00:15].
 - Creating a Pattern: Modeling a small wedged cut on the handle and then using a linear pattern to create a straight knurl [03:22].
 - Managing Revisions: How to handle changes to parts and assemblies by creating new revisions and saving them to the 3DEXPERIENCE platform [05:08].
Step-by-Step Instructions (AI-generated from video transcript):
Based on the video at https://youtu.be/zjMe-0NmoqY, here are step-by-step instructions for modifying the handle and creating a linear pattern:
Part 1: Open the Handle Part
- Open the assembly in SOLIDWORKS from the 3DEXPERIENCE platform.
 - In the assembly's FeatureManager design tree, right-click on the handle and select "Open Part" to open it in a new window.
Part 2: Create the Knurl Cut
- Start a new sketch on the top face of the handle.
 - Use the Line tool to draw a small, wedge-shaped triangle at the desired location for the knurl.
 - Use the Extruded Cut feature and set the depth to "Through All" to cut the shape through the entire handle.
Part 3: Create the Linear Pattern
- Select the Linear Pattern feature.
 - For Direction 1, select the edge of the handle that runs parallel to the cut.
 - Set the desired spacing and the number of instances for the pattern. The video uses 50 instances at 0.5 millimeters apart.
 - For Features and Faces to Pattern, select the extruded cut you just created.
 - Click the green checkmark to complete the pattern.
Part 4: Manage Revisions and Save
- After making changes, click the Save icon.
 - The 3DEXPERIENCE platform will ask you to create a new revision.
 - Give the new revision a title, such as "with knurl."
 - If you have the assembly open, the platform will notify you that the part has changed. Select the new revision to update the assembly.
 - Lock the part and the assembly on the 3DEXPERIENCE platform to prevent others from editing them while you are working.
More Info
Roles:
 solidworks with cloud services   3DEXPERIENCE SOLIDWORKS
Tags:
beginners guide SOLIDWORKS revisions Pattern
Feedback
Was this page useful?
Hit the Like Button, or let us know what we can improve in the Comments Section below.
