Getting Started | Admin Path
 Getting Started as an Administrator
Platform Admin | First Steps
  Access Your Platform for the First Time
 Your First Steps as a Platform Administrator
Platform Admin | Basics
 Create a Place to Store Your 3D Data Using Collaborative Spaces
 Create a Folder Structure Using Bookmark Editor
 Create a Community for Team Collaboration
Install Your Roles and Applications
Learn how to install your Design, Simulation, Governance, or Manufacturing roles. Then return to the Admin or Member path to learn how to set up an use your Roles and Apps on the 3DEXPERIENCE platform.
 Switch to the Member Path
Platform Admin | Extended Capabilities
  Create a Dashboard and Share with Platform Members
  Map Attributes Between SOLIDWORKS and the 3DEXPERIENCE Platform
  Create Content Naming Rules
  What other Learning Resources are Available?
Other Resources for 3DEXPERIENCE platform Administrator's
Best Practices for using SOLIDWORKS Solutions on Desktop and Cloud. These best practice guides are designed for you to make the most out of your solutions and unlock true value.
Explore the Platform Manager Role (3DEXPERIENCE EDU)
In this module, you will learn how to configure the 3DEXPERIENCE platform on cloud to set a scalable environment and well-organized applications.
Platform Configuration for SOLIDWORKS Users (MySolidWorks)
In this learning path, you will learn how to use the platform management tools and the Platform Manager role to setup and configure the 3DEXPERIENCE platform for SOLIDWORKS users.
3DEXPERIENCE EDU for 3DEXPERIENCE Works
Access the full catalog of role learning paths and modules for the 3DEXPERIENCE Works portfolio of roles.
3DEXPERIENCE Learner Library is required to access the catalog. Contact your Reseller Partner for more information
Navigate back to the SOLIDWORKS Learning Resources WIKI and check out the resources available for your SOLIDWORKS learning journey.
Roles: 3dswymer  collaborative industry innovator   ​​​​​​collaborative designer for SOLIDWORKS   SOLIDWORKS Design SOLIDWORKS xDesign  DraftSight Project Planner Admin
Tags: member SOLIDWORKS 3DEXPERIENCE platform
Feedback
Was this page useful?
Hit the Like Button, or let us know what we can improve in the Comments Section below.
