Your First Part Design
Learn the basics of SOLIDWORKS CAD while modeling a simple cylinder part design
What is covered?
- Interface Overview: It introduces key parts of the SOLIDWORKS user interface, including the menu bar, command manager, feature manager design tree, task pane, and heads-up view toolbar [00:34].
 - Document Types: Explains the three types of documents in SOLIDWORKS: parts, assemblies, and drawings [00:48].
 - Setting up a New Part: This includes starting a new part document, changing scene settings, and setting part units to inches, pounds, and seconds (IPS) [00:40].
 - 2D Sketching: It demonstrates creating a new sketch, using the circle command, adding dimensions, and the concept of fully constrained sketches [01:59].
 - Creating a 3D Feature: It shows how to use the extruded boss base feature to turn a 2D sketch into a 3D solid [05:09].
 - View Manipulation: The video explains how to change view settings, rotate, zoom, and pan the view, and use the view selector for predefined views [05:41].
 - Saving to the 3DEXPERIENCE platform: It covers saving the part, assigning a title, and using collaborative spaces and bookmarks for organization [06:33].
Step-by-Step Instructions (AI-generated from video transcript):
Based on the video at https://youtu.be/qjtYqxNpj50, here are step-by-step instructions for creating a simple 3D part in SOLIDWORKS.
Part 1: Getting Started
- Open a new part document: From the SOLIDWORKS interface, start a new part file.
 - Set units: Change the units for your part document to your preferred system, such as IPS (inch, pound, second).
Part 2: Creating a 2D Sketch
- Select a plane: Choose a plane, such as the Front Plane, to create your sketch on.
 - Create a sketch: Begin a new sketch on the selected plane.
 - Use sketching tools: Use a tool like the Circle command to sketch your 2D shape. Start your sketch at the origin to fully define its position.
 - Add dimensions: Use the Smart Dimension tool to define the size of your sketch. For a circle, this would be its diameter.
 - Exit the sketch: Once your sketch is fully defined (indicated by the lines turning black), exit the sketch environment.
Part 3: Creating a 3D Feature
- Extrude the sketch: Go to the Features tab and use the Extruded Boss/Base command to turn your 2D sketch into a 3D solid.
 - Set extrusion depth: Define the desired depth for your 3D part.
Part 4: Viewing and Saving
- Manipulate the view: You can rotate the model using the middle mouse button, zoom in and out by scrolling, and pan the view by holding Ctrl and the middle mouse button.
 - Save the part: Save your new part to the 3DEXPERIENCE platform, giving it a title and assigning it to a collaborative space and bookmark for organization.
More Info
Roles:
 solidworks with cloud services   3DEXPERIENCE SOLIDWORKS
Tags:
beginners guide cloud services 3DEXPERIENCE platform
Feedback
Was this page useful?
Hit the Like Button, or let us know what we can improve in the Comments Section below.
