Sketch and Extrude
Learn how to create a Sketch in SOLIDWORKS, and then use the Extruded Boss/Base feature to add depth and volume
What's Covered?
- Setting up the Environment: The video demonstrates how to create a new part, change the units to IPS (inch, pound, second), and set a plain white background [00:22].
 - Sketching the Plier Head: It shows how to sketch the plier head on the front plane using circles and lines, then add dimensions and geometric relations to fully define the sketch [00:39].
 - Extruding the Plier Head: The video explains how to use the Extruded Boss/Base feature to extrude the sketched profiles into a 3D solid [03:26].
 - Sketching the Plier Handle: It details how to create a new sketch on the plier head's face and sketch the handle using a three-point arc and construction lines, followed by dimensioning [04:15].
 - Extruding the Plier Handle: Finally, it shows how to extrude the open sketch of the handle using the "thin feature" option and ensure the "merge result" option is active to create a single solid body [06:00].
Step-by-Step Instructions (AI-generated from video transcript):
Based on the video at https://youtu.be/W-7UGc8uDTc, here are step-by-step instructions for modeling a pair of needlenose pliers in SOLIDWORKS.
Part 1: Setting up the Environment
- Start a new part: Create a new part document.
 - Set units: Change the document units to inches, pounds, and seconds (IPS).
 - Set background: Change the background to a plain white color.
Part 2: Sketching the Plier Head
- Begin a sketch: Start a new sketch on the Front Plane.
 - Draw the main circle: Sketch a circle starting at the origin.
 - Dimension the circle: Use the Smart Dimension tool to set the diameter of the circle.
 - Sketch the rest of the head: Draw lines from the circle to create the shape of the plier head.
 - Add relations and dimensions: Add geometric relations (like vertical and horizontal) and use Smart Dimensions to fully define the sketch, including an angled dimension using a construction line.
Part 3: Creating the Plier Head
- Extrude the sketch: Select the Extruded Boss/Base feature. Since your sketch is active, it will be automatically selected.
 - Select profiles: Choose the individual areas within your sketch that you want to extrude.
 - Extrude with midplane: In the property manager, set the extrusion to "Midplane" to extrude equally in both directions.
Part 4: Sketching and Creating the Plier Handle
- Start a new sketch: Begin a new sketch on the front face of the plier head.
 - Create a construction line: Draw a construction line from the midpoint of the plier head to use as a reference for the handle.
 - Sketch the handle: Use a three-point arc to sketch the shape of the handle.
 - Add dimensions: Dimension the arc's width, length, and radius.
 - Extrude the handle: With the sketch active, select the Extruded Boss/Base feature.
 - Use the "thin feature" option: Because the handle is an open sketch, activate the "thin feature" option and set the thickness.
 - Reverse direction: Reverse the extrusion direction if needed.
 - Merge results: Ensure the "Merge result" box is checked to combine the handle with the plier head into a single solid body.
More Info
Roles:
 solidworks with cloud services   3DEXPERIENCE SOLIDWORKS
Tags:
beginners guide SOLIDWORKS Sketch
Feedback
Was this page useful?
Hit the Like Button, or let us know what we can improve in the Comments Section below.
