Cut Extrude
Learn how to use the Cut Extruded feature to remove material and volume from your part design
What's Covered?
- Creating a sketch for a cut: The video shows how to create a sketch on a model's face using the Circle and Smart Dimension tools to define a hole for a pin [00:22].
- Using Cut Extrude: It explains that the Cut Extrude feature is used to remove material, which is the opposite of the Extruded Boss Base feature that adds material [00:50].
- Through All option: The video demonstrates how to use the Through All option to make sure the cut goes through the entire model [01:06].
- Using existing sketches: It shows how to reuse a previously defined sketch to create a cutout that forms the joining faces of the pliers [01:25].
- Using an open sketch: The video demonstrates how to use an open sketch profile to narrow the head of the pliers with a cut extrude [02:17].
- Flip Side to Cut: It explains the Flip Side to Cut option, which allows you to control which side of the sketch the material is removed from [03:16].
Step-by-Step Instructions (AI-generated from video transcript):
Based on the video at https://youtu.be/RKIEQVR-qJw, here are step-by-step instructions for using the Cut Extrude feature in SOLIDWORKS.
Part 1: Creating a Sketch for a Hole
- Select a face: Select the face of the model where you want to create a hole. In the video's example, this is the front face of the plier head.
- Start a sketch: Create a new sketch on the selected face.
- Draw a circle: Use the Circle tool to draw a circle where the hole will be located.
- Add dimensions: Use the Smart Dimension tool to define the size of the circle and its location relative to the model's features.
Part 2: Extruding the Cut
- Access Cut Extrude: Go to the Features tab and select the Extruded Cut feature.
- Set direction: Under the Direction 1 options, choose Through All to ensure the cut goes through the entire part.
- Confirm: Click the green checkmark to complete the cut.
Part 3: Using a Sketch to Cut a Feature
- Show the sketch: If the sketch you want to use is hidden, right-click on it in the FeatureManager Design Tree and select Show.
- Select sketch and cut: Select the sketch in the FeatureManager Design Tree, then choose the Extruded Cut feature.
- Set direction: Use the Through All option to cut through the entire part.
Part 4: Using an Open Sketch to Cut
- Create an open sketch: On the desired face, create a new sketch using an open profile (a line or series of lines that do not form a closed loop).
- Access Cut Extrude: Select the sketch and choose the Extruded Cut feature.
- Flip the cut side: In the property manager, use the Flip Side to Cut option to make sure the material is removed from the correct side of your sketch.
- Set direction: Set the cut direction to Through All.
More Info
Roles:
solidworks with cloud services 3DEXPERIENCE SOLIDWORKS
Tags:
beginners guide SOLIDWORKS Cut Extrude
Feedback
Was this page useful?
Hit the Like Button, or let us know what we can improve in the Comments Section below.
