What is HomeByMe and why should I publish my model there?
HomeByMe is a free and easy to use home design service. It allows you to model room layouts for your home, apartment, or garage, as well as exterior spaces such as a gardens, patio, and driveways. You can place furnishings and other objects from hundreds of brands into the design to visualize how they would look and fit in the real world.
As a Maker, you can design your own furniture in xDesign, xShape, or SOLIDWORKS Connected, and publish it to HomeByMe Community Content. Then, you can place your model into a HomeByMe project of your design to see how it will fit in the space before you purchase or cut any material to make it! You can also be inspired by the creations of other Makers by viewing their contributions to the Community Content. Use the power of 3DSwym to communicate with each other and start building together!
Create a free HomeByMe account today to get started.
Publish from xApps Workflow:
- Open xDesign or xShape
 - Open or create your model, making sure it is saved in a Collaborative Space that you are the owner or leader of
 - Navigate to the Tools tab of the Action Bar
 - Select the arrow next to the Publish icon and choose "Share as 3D"
 - In the publish panel, set the tenant to Dassault Systemes
 - Set the community to MAKERS | Made In 3D
 - Type a title that is easy to search for
 - Type a description that applies to your model
 - Choose whether others should be allowed to edit a 3DXML of your model or not
 - Check the box to Publish to HomeByMe
 - Select the appropriate category for your model to be sorted into
 - Publish!
Publish from SOLIDWORKS Connected Workflow:
- Open SOLIDWORKS Connected
 - Open or create your model, making sure it is saved in a Collaborative Space that you are the leader or owner of
 - Navigate to the Tools menu in the menu bar
 - Select "Publish to HomeByMe"
 - Publish!
