Introduction
This document intended to provide a detailed guide and examples on how to write EKL script to set variant effectivity on Mfg. Item.
Along with set variant effectivity on Mfg Item there are example EKL actions to unset variant effectivity on Engineering Item, Resource and System.
Version – 2021x FD09 (FP2140), 2022x FD08 (FP2319), 2023x FD04 (FP2333), 2026x GA
Pre-requisites
Licenses – These EKL scripts call 3DSpace web services, which require specific licenses to execute as mentioned in below table. (These are referred from developer documentation of web services)
Mfg. Item related web services
• MFN (DELMIA Manufactured Items Management)
• CSV (Industry Innovation) For Reading Web Services
Model configuration, effectivity or IP Configuration related web services
• CFG (Configuration Management), for all dscfg web services
• CSV (Industry Innovation), For Reading Web Services
Disclaimer: Licenses mentioned above are as per 2021x, 2022x and 2023x documentation.
Logical Flow
The sequence of the scripts/ steps for this set effectivity EKL script is the following.
Example
Disclaimer: This code is just an example and should only be used by people who know the Enterprise Knowledge Language (EKL) and the DELMIA data model very well. The intent is not to provide a ready to deploy product code. So we are not responsible for any issues you may face with this code.
Detail Explanation
Pre-requisite
Before calling the script to set the Variant Effectivity, it is needed to
- Create a Model, Variants and Variant values.
- Set/attach the configuration context on the Root or the Parent of the object, on which one want to set the Variant Effectivity. One can manually set the Configuration context or can use the EKL script available here.
How to call web services
Steps followed for calling all web services.
- Create HTTP client.
- Define header for the HTTP client.
- Build web service URI.
- Perform GET/POST request.
- Retrieve the returned response code if it is zero / as per documentation then ok else error case.
- To retrieve the required content from the response traverse through returned data node or buffer.
For example – Below script calls web service to set effectivity of Mfg. Item instance.
In attached EKL we used hard coded effectivity expression which can be manipulated as per user requirement. Or this can be retrieved from Get effectivity script and set on selected Mfg. Item instance.
//Set Effectivity on Instance found in above step
// Creates an HTTP client
client = CreateHTTPClient()
// Defines Headers
client.AddRequestHeaders("Content-Type: application/json")
client.AddRequestHeaders("Accept: application/json")
client.AddRequestHeaders("SecurityContext: "+securityCtx)
client.AddRequestHeaders("ENO_CSRF_TOKEN: "+csrfToken)
//Modify the Variant Content as needed
let strVariantContent (String)
//Variant content having only single Variant and its value
strVariantContent= " "
//Varient content having multiple Varients and their values
//strVariantContent= " "
//Let act1 (AdvisorAction)
//act1 = `Knowledge Engineering Specification Physical00000084 A.1\\Relations\\Get Variant Effectivity On Mfg Item V1.0`
//act1.Run(selMfgItemOcc, strVariantContent)
if strEffectivityXprsn == "" AND strVariantContent == ""
PopupMessage("Effectivity Expression not found, please send valid effectivity expression.")
break
else if strVariantContent <> "" AND strEffectivityXprsn == ""
strVariantContent = strVariantContent
else
strVariantContent = strEffectivityXprsn
Let jsonBody(String)
// Defines URI and Body
iURI = serverURL +"/resources/v1/modeler/dscfg/invoke/dscfg:setVariant"
jsonBody = "[{"
jsonBody = jsonBody + "\\"identifier\\": \\""+strSelctMfgItemInstPID+"\\","
jsonBody = jsonBody + "\\"type\\": \\"dsmfg:MfgItemInstance\\","
jsonBody = jsonBody + "\\"source\\": \\"3DSpace\\","
jsonBody = jsonBody + "\\"relativePath\\": \\"/resources/v1/modeler/dsmfg/dsmfg:MfgItem/"+strFatherRefPid+"/dsmfg:MfgItemInstance/"+strSelctMfgItemInstPID+"\\","
jsonBody = jsonBody + "\\"variantContent\\": \\""+ReplaceAll(strVariantContent,"\\"","\\\\\\"")+"\\""
jsonBody = jsonBody + "}]"
//Performs a POST request
oBuffer = client.Post(iURI, "HTTPDEFINED", jsonBody, oDTN)
// Checking if request return code is OK (rc = 0)
if (client.ReturnCode == 0)
// success
PopupMessage("Success")
PopupMessage("client.ReturnCode - #, oBuffer - #", client.ReturnCode, oBuffer)
/*Let lEntities(List)
lEntities.Append(selMfgItemOcc)
RefreshEntities(lEntities, false)*/
else
// failure
}How to define the Input Effectivity Expression in XML format for web service
The effectivity expression, which will be used as the input for the EKL script to send to the we service needs to be given in the XML format.
One can either use the input string argument "strEffectivityXprsn" to pass the effectivity expression or one can edit the already available Effectivity Expression, which is defined as a string variable "strVariantContent" in the script on line 175 (For single Variant and its value) or 178 (For multiple Variants and their values).
If the "strEffectivityXprsn" is empty, then the script will use the value stored in "strVariantContent" as a Effectivity Expression.
Below are the guidelines to edit the effectivity expression:
For single variant and its value
For effectivity expression having single variant and its value, use the following XML format
Below is the explanation of the above XML expression
The above Effectivity Expression will result into Variant Effectivity as given below:
Here, the "
Note: "Name" is the internal "Name" attribute of the Model, Variant or Value
Edit the Model Name, Variant Name and Variant Value Name before executing the script.
For Multiple variant and its value
For effectivity expression having multiple variants and their values, use the following XML format
Here, the "
If there are multiple "Variants" used in the Effectivity Expression, then the "
Edit the Model Name, Variant Names and Variant Values Name before executing the script.
Get selected instance / Relationship Object ID
To unset / set / get variant effectivity it needs instance / relationship object ID.
- To get instance Object ID:
//Get instance name of selected Mfg Item
Let selMfgItemInst(PLMCoreInstance)
set selMfgItemInst = selMfgItemOcc.Instance
//Get Physical ID of selected Mfg Item instance
let strSelctMfgItemInstPID(String)
strSelctMfgItemInstPID=selMfgItemInst.GetPhysicalId()
- To get object ID of Father Mfg. Item reference:
let selMfgItemFatherRef(DELFmiFunctionReference)
let selMfgItemFatherOcc(MfgProcessOccurrence)
let strFatherRefPid(String)
set selMfgItemFatherOcc=selMfgItemOcc.Owner
if(selMfgItemFatherOcc <>NULL)
//Get Physical ID of owner / father of selected object which has configuration model attached.
selMfgItemFatherRef=selMfgItemFatherOcc.Reference
strFatherRefPid=selMfgItemFatherRef.GetPhysicalId()
Here under some Use Case about possible adaptation of the script
1. Requirement 1: Set effectivity on other type of objects in structure
In above example we saw detailed explanation of how the script is written to set the effectivity of Mfg. Item, there might be requirement where we need to set effectivity on Eng. Item, System or Resource objects. In this case, user need to modify above script and reuse them.
Below are some of the changes required in the script to use it for Eng. Item, System or Resources.
- Object selection
Based on to which type of object we want to set effectivity we will set its type.
| Mfg Item | Eng Item | System | Resource |
| MfgProcessOccurrence | ProductOccurrence | ProdSystemOccurrence | ResourceOccurrence |
- Use respective corpus type
In our example we used dsmfg/dsmfg:MfgItem instead of that if set effectivity is to be done on system object then use dsprcs/dsprcs:MfgProcess similar for other type of objects.
| dsmfg/dsmfg:MfgItem | dseng/dseng:EngItem | dsprcs/dsprcs:MfgProcess | dsrsc/dsrsc:Resource |
| dsmfg:MfgItemInstance | dseng:EngInstance | dsprcs:MfgProcessInstance | dsrsc:ResourceInstance |
| dsprcs:MfgOperation | |||
| dsprcs:MfgOperationInstance |
//Web Service Search Query with Parameter for Mfg Item
requestURI= serverURL + "/resources/v1/modeler/dsmfg/dsmfg:MfgItem/search?\\\$searchStr=" + PLMID + "&\\\$top=50&\\\$skip=0"
//Web Service Search Query with Parameter for System
requestURI= serverURL + "/resources/v1/modeler/dsprcs/dsprcs:MfgProcess/search?\\\$searchStr=" + PLMID + "&\\\$top=50&\\\$skip=0"2. Requirement 2: Set Evolution effectivity on Mfg. Item
Above example shows how to set variant effectivity on Mfg. Item, similarly if user want to set Evolution effectivity then below are some changes required in above EKL script.
- Web service URI
Modify web service URI as shown below,
// For setVariant Effectivity Defines URI as below,
// For setEvolution Effectivity Defines URI as below,
iURI = serverURL +"/resources/v1/modeler/dscfg/invoke/dscfg:setEvolution"- Effectivity Expression
Modify effectivity expression as per evolution effectivity to apply, below is an example,
" "- JSON Body
Build JSON request body as shown below with required identifiers and evolution expression. For more details refer Developer assistance for 2021x.
// Define Variant effectivity expression
// Defines URI and Body For SetVariant Effectivity
jsonBody = "[{"
// Define Evolution effectivity expression
let strEvolutionContent (String)
strEvolutionContent = " "
// Defines URI and Body For SetEvolution Effectivity
jsonBody = "[{"
jsonBody = jsonBody + "\\"evolutionContent\\": \\""+ReplaceAll(strEvolutionContent,"\\"","\\\\\\"")+"\\""
jsonBody = jsonBody + "}]"For example – below is an example of JSON body to pass to setEvolution Effectivity web service method.
"identifier": "F6AF82561E5700005EB271EE0003C500",
"evolutionContent": " ",
"type": "dseng:EngInstance",
"source": "3DSpace",
"relativePath": "/resources/v1/modeler/dseng/dseng:EngItem/F6AF82561E5700005EB123650003C100/dseng:EngInstance/F6AF82561E5700005EB271EE0003C500"
]Note – Always use internal name for all variant values, features, Model name, product state, etc...
How to Deploy
Follow below steps to deploy the above EKL script
- Download the Provided EKL Script
- Create one new "Physical Product" to act as container for the EKL action and give it some suitable name. For ex. "Set_Variant_Effectivity_EKL_script"
- Create a new "Knowledge Action" in the newly created Physicals Product. Follow the sample video available on this page to know "How to create Knowledge Action".
- Set the input arguments as explained at the top of the script in the "Input output argument" comment.
- Edit the "strVariantContent" variable value for your model and variant. (Use variable on line 175 for single variant and use variable on line 178 for multiple variants)
- Save the script
- Execute the script
Author
Author- @RR
For any queries, please reach out to - @KA
