| ▶Benefits of tags: |
| ⭐Tagging content with specific tags makes it easier to find and filter the content later. |
| ⭐Readers can click on any tag to display all content with this tag. |
Two ways to add tags
1) Add a tag within your content - use this method when you want the tag to be visible
- You can create a tag by typing the hashtag symbol (#) and then typing your tag name. For example, you might decide to tag a post related to cloud...
- Once you begin typing your tag, a drop-down list appears, showing frequently-used tags followed by the 6W options.
- Select the tag you wish to use
Some communities also have Community Tags set up by the Community owner. You will see them listed at the bottom of your draft post - simply click to select the ones that you would like to add.
2. Add a tag with the 6WTagger
- Open up the 6WTags by clicking on the tag symbol next to the search bar at the top.
- You can add tags in this side panel.
✅ A convenient way to add multiple tags at once.
Note: the tag doesn't display directly in the post.
