[SIMULIA] Fluid Dynamics Engineer
Easily model e-cooling applications with the ability to use electronics cooling component models in the geometry-based workflow
Accurately model applications such as centrifugal pumps with the ability to simulate rotating geometry in the geometry-based workflow
Visualize flow path more accurately with new option to space streamlines marker by time intervals
User Experience Value
Shorten the learning curve using the geometry-based workflow with enhancements to the assistant for geometry idealization
Streamline thermal simulations with an improved user experience to assign materials for solid physics domains
Immediately assess product performance with a new KPI-centric approach to Results Exploration, introducing new Goals command in Physics Results Explorer
Decrease simulation time and cost by using unsupervised KPI stopping criteria
Assess fluid performance intuitively with direct selection of Scenario feature as support for Field Sensors
I
Decrease of simulation time and cost by enabling unsupervised KPI stopping criteria.
I
Easily and accurately model applications such as centrifugal pumps with the ability to simulate true rotating geometry in the geometry-based workflow.
I
Improved conjugate heat transfer simulation setup by streamlining how materials are applied to solid domains.
Assess fluid performance intuitively with direct selection of Scenario feature as support for Field Sensors.
Immediately assess product performance with a new KPI-centric approach to Results Exploration, introducing new Goals command in Physics Results Explorer.
Visualize flow path more accurately with new option to space streamlines marker by time intervals.
