| 3DEXPERIENCE R2026x FD02 |
| 3DEXPERIENCE release | Hotfix level | Date | Content |
| R2026x_FD02 | HF2.2 (3DEXPERIENCETransitionAssistant) | 2026/06/11 | - This HF fixes issue Error Export KO but no specific message
Reference: BR10000421948
| R2026x_FD02 | HF3.24 (HF_NativeApps_3DEXP_Cloud ) | 2026/06/10 | - This HF fixes issue Harness configuration failure in Electrical 3D Design applications
Reference: BR10000411886 - This HF fixes issue related to Simulation Execution failure on private station
| R2026x_FD02 | HF3.22 (HF_NativeApps_3DEXP_Cloud ) | 2026/06/05 | - This HF fixes issue CAD conversion of a structure containing a drawing results in two instances of the same drawing.
Reference:BR10000422009 - This HF fixes issue CAD Transition - New Revision is allowed from any existing revision even with if the rule platforme is setted at false
Reference:BR10000424109 - This HF fixes issue CAD Transition : After a "As new revision" the core material is not reconducted
Reference:BR10000424377
| R2026x_FD02 | HF3.21 (HF_NativeApps_3DEXP_Cloud ) | 2026/06/02 | |
| R2026x_FD02 | HF3.20 (HF_NativeApps_3DEXP_Cloud ) | 2026/05/28 | - This HF fixes crash issue when launching move point cloud command in the PLA app.
| R2026x_FD02 | HF3.10 (SOLIDWORKS_3DEXP_Desktop ) | 2026/05/25 | - This HF fixes issue of unexpected instability using 'Save All' to 3DEXPERIENCE command
Reference:BR10000422236 - This HF fixes issue with the SOLIDWORKS file property of type "Equation" is not mapped to a 3DX attribute of type "Real" when decimal seperator is (,)
Reference:BR10000421954
| R2026x_FD02 | HF3.19 (HF_NativeApps_3DEXP_Cloud ) | 2026/05/23 | - This HF fixes issue related to crash occurs after saving mannequin
Reference:BR10000425674
| R2026x_FD02 | HF3.18 (HF_NativeApps_3DEXP_Cloud ) | 2026/05/21 | - This HF fixes issue with disappearance of certain published parameters depending on their order within a UDF
Reference:BR10000422252 - This HF fixes issue with parameter association for Layer thickness is not available from 26xGA
Reference:BR10000421384 - This HF fixes issue QccBatchReport UTILITY : profiles not displayed in window
Reference:BR10000424892
| R2026x_FD02 | HF3.9 (SOLIDWORKS_3DEXP_Desktop ) | 2026/05/21 | - This HF fixes issue "Save with options" does not remove old entries in "tew_3dxaddin.sqlite", causing problems managing revisions
| R2026x_FD02 | HF3.4 (HF_XCADDesignConnectors ) | 2026/05/20 | - This HF fixes issue with the SOLIDWORKS file property of type "Equation" is not mapped to a 3DX attribute of type "Real" when decimal seperator is (,)
Reference:BR10000421954 - This HF fixes issue with Unexpected instability using 'Save All' to 3DEXPERIENCE command
| R2026x_FD02 | HF3.17 (HF_NativeApps_3DEXP_Cloud ) | 2026/05/13 | |
| R2026x_FD02 | HF3.8 (SOLIDWORKS_3DEXP_Desktop ) | 2026/05/12 | This HF fixes issue related to 3DEXPERIENCE window(s) opens and install does not start when updating from Check for Updates Reference:BR10000424770 This HF fixes issues related to Search / Replace of Filename does not work in Pack and Go when run from SOLIDWORKS Design with the 3DEXPERIENCE add-in enabled Reference:BR10000424866 This HF fixes issues related to 'Allow other apps and services on this device' CEF prompt prevents Check for Updates install from starting Reference:BR10000425201
| R2026x_FD02 | HF2.1 (3DEXPERIENCETransitionAssistant) | 2026/05/11 | - This HF fixes issue on XTA error report 1893 files are reported as missing for a single job
Reference:BR10000413803 - This HF fixes issue when migrating an Assembly, several objects fail with the status 'Export KO'
Reference:BR10000419116 - This HF fixes issue with 3DEXPERIENCE Transition Engine Looping issue
Reference:BR10000419651 - This HF fixes issue when migrating a CATProduct several Objects get the state 'Export KO'
Reference:BR10000420969 - This HF fixes issue Error while import : Incorrect inputs to finalize the import job.
Reference:BR10000421228 - This HF fixes issue with bookmark folders are linked to the wrong parent bookmarks in 3DEXPERIENCE
Reference:BR10000421391 - This HF fixes issue with only the first drawing revision is included in scope when transferring associated part using 3DTA
Reference:BR10000421500 - This HF fixes issue with Project Query saved in SmarTeam is not available/visible in dropdown list in Analyzer window
Reference:BR10000421601 - This HF fixes issue to Create Mapping File" for EIN doesn't create the csv file
Reference:BR10000421625 - This HF fixes issue Depth logic is not working when the FTA tool is installed on machine having CXR35 CATIA.
- This HF fixes issue with Parent assembly fails to migrate after CLASS_ID implementation
| R2026x_FD02 | HF3.7 (SOLIDWORKS_3DEXP_Desktop ) | 2026/05/11 | - This HF fixes issue related to Leo timeout issue due to different server names used in payload
| R2026x_FD02 | HF3.16 (HF_NativeApps_3DEXP_Cloud ) | 2026/05/06 | - This HF fixes issue related to Session Crash on Closing Predict Results Dialog.
| R2026x_FD02 | HF3.15 (HF_NativeApps_3DEXP_Cloud ) | 2026/05/05 | |
| R2026x_FD02 | HF3.14 (HF_NativeApps_3DEXP_Cloud ) | 2026/04/29 | - This HF fixes issues related to Deletion of ML Grid data from Physics Behavior app.
- This HF fixes issues related to Simulation Execution fails for local non-interactive when WU and WA licenses are split between 2 license servers.
| R2026x_FD02 | HF3.13 (HF_NativeApps_3DEXP_Cloud ) | 2026/04/29 | - This HF fixes issue related to Expose variants
| R2026x_FD02 | HF3.6 (SOLIDWORKS_3DEXP_Desktop ) | 2026/04/28 | - This HF fixes issue related to SOLIDWORKS Crashing after clicking on "Drawing Creation".
| R2026x_FD02 | HF3.5 (SOLIDWORKS_3DEXP_Desktop ) | 2026/04/26 | |
| 3DEXPERIENCE R2026x FD01 |
| R2026x_FD01 | HF1.39 (HF_NativeApps_3DEXP_Cloud ) | 2026/06/10 | - This HF fixes issue related to Simulation Execution failure on private station
| R2026x_FD01 | HF1.38 (HF_NativeApps_3DEXP_Cloud ) | 2026/04/26 | |
| R2026x_FD01 | HF1.37 (HF_NativeApps_3DEXP_Cloud ) | 2026/04/09 | |
| R2026x_FD01 | HF1.36 (HF_NativeApps_3DEXP_Cloud ) | 2026/04/07 | - This HF fixes issue with Drawing's title not conserved during the conversion with CAD transition
Reference:BR10000420456 - This HF fixes issue related to Crash with polyline tool.
Reference:BR10000421352 - This HF fixes issue when symmetric product is created with a 3DShape Instead of the original representation type 3D shape Skeleton.
Reference:BR10000421848 - This HF fixes issue with Disappearance of certain published parameters depending on their order within a UDF.
Reference:BR10000422252 - This HF fixes issue with Loop inside a User Operator is in Error after instantiation
| R2026x_FD01 | HF1.35 (HF_NativeApps_3DEXP_Cloud ) | 2026/04/03 | - This HF fixes issue while Importing the .zip file on ER Generic Server Openings inside Data Setup app closes the native apps abruptly
Reference:BR10000421966
| R2026x_FD01 | HF1.1 (ENOVIA_DerivedFormatConverter) | 2026/04/02 | - This HF fixes Intermittent issue with apostrophe/text in PDF created by Derived Format Converter of CATDrawing
Reference:BR10000402780
| R2026x_FD01 | HF1.34 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/30 | |
| R2026x_FD01 | HF1.1 (HF_XCADDesignConnectors )
HF1.9 (SOLIDWORKS_3DEXP_Desktop ) | 2026/03/25 | This HF fixes issue related to Cad model's child components are not showing in Catia and SolidWorks. Reference:BR10000420639 This HF fixes issues related to 'Please save the opened documents before opening a filtered assembly' warning opening a filtered product structure in SOLIDWORKS Design Reference:BR10000421718
| R2026x_FD01 | HF1.32 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/25 | - This HF fixes issue related to Session crashes after selecting Cancel button in Compare tool path dialog.
- This HF fixes issue related to Scale 150% and more crop buttons in Macro panel.
- This HF fixes issue related to strange results after defining overhang to 0 in machining surface extended.
- This HF fixes issue related to Crash when opening data
Reference:BR10000419694 - This HF fixes issue related to System crashes when users define their own categories for Feeds & Speeds.
- This HF fixes issue related to edit PPword instruction the existing text is empty.
- This HF fixes issue related to a measure criteria is applied during feature recognition the system enters an infinite loop in this dataset.
| R2026x_FD01 | HF1.31 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/24 | - This HF fixes issue related to Delay in switching to tab where Suspension Analysis App is open
Reference:BR10000418116
| R2026x_FD01 | HF1.30 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/23 | Reference:BR10000408639 |
| R2026x_FD01 | HF1.8 (SOLIDWORKS_3DEXP_Desktop ) | 2026/03/20 | - This HF fixes issue related to SOLIDWORKS Design crash after launch or when using web-based task panes with Microsoft Edge WebView2 Runtime 146 installed
Reference:BR10000422063
| R2026x_FD01 | HF1.29 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/19 | - This HF fixes issue related to Position Mismatch After FBX Import into 3DEXPERIENCE
Reference:BR10000417173
| R2026x_FD01 | HF1.28 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/18 | |
| R2026x_FD01 | HF1.27 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/16 | - This HF fixes issue related to Machining - Not possible to open manufacturing cell
Reference:BR10000421551
| R2026x_FD01 | HF1.26 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/13 | |
| R2026x_FD01 | HF1.7 (SOLIDWORKS_3DEXP_Desktop ) | 2026/03/12 | This HF fixes issue related to Crash opening SOLIDWORKS drawing Reference:BR10000419967 This HF fixes issues related to AI Lab Drawing Creation skill fails with 'LEO is not able to answer right now...' error Reference:BR10000420800 This HF fixes issues related to Impossible to define a Bolt Connector between solid bodies (error “Select entity on shell”) when Beams or Shells are present in the study Reference:BR10000421004
| R2026x_FD01 | HF1.25 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/11 | - This HF fixes issue related to Play Optimization widget: Batching create corrupted geometries
| R2026x_FD01 | HF1.24 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/11 | - This HF fixes issue "Future version not supported" error message pops-up when importing SOLIDWORKS 2026 version file
Reference:BR10000420183
| R2026x_FD01 | HF1.23 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/10 | - This HF fixes issue Planning Structure app is crashing when EBOM data Switch to Light 3D Mode
Reference:BR10000420751
| R2026x_FD01 | HF1.22 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/06 | - This HF fixes issue related to Aggregated shapes are not promoted with their parent physical product after minor revision
Reference:BR10000416306
| R2026x_FD01 | HF1.21 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/04 | - This HF fixes issue related to CST interactive session writing large cgr files to container /tmp
| R2026x_FD01 | HF1.20 (HF_NativeApps_3DEXP_Cloud ) | 2026/03/03 | |
| R2026x_FD01 | HF1.6 (SOLIDWORKS_3DEXP_Desktop ) | 2026/02/27 | - This HF fixes issue with SolidWorks Visualize 2026 SP1.1 crashes when choosing File, Exit
Reference:BR10000420206 - This HF fixes issue with SolidWorks Visualize 2026 SP1.1 may crash after 30 minutes of use
Reference:BR10000420417 - This HF fixes issue with 'SOLIDWORKS PinPoint Install failed code:12' installing SOLIDWORKS Design in on-demand mode after uninstalling it
Reference:BR10000420628
| R2026x_FD01 | HF1.19 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/27 | |
| R2026x_FD01 | HF1.18 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/26 | |
| R2026x_FD01 | HF1.17 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/25 | - This HF fixes issue impossible to apply a variant model
Reference:BR10000419399
| R2026x_FD01 | HF1.16 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/25 | - This HF fixes issue related to the largest glb file have the same number of draw calls for batched and non-batched dsxm's
| R2026x_FD01 | HF1.15 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/19 | - This HF fixes issue related to Detect and identify is KO
- This HF fixes issue related to Movie Point cloud is KO
| R2026x_FD01 | HF1.14 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/18 | - This HF fixes issue related to FEM symmetry plane gets deleted for mirror FEM after importing data
| R2026x_FD01 | HF1.5 (SOLIDWORKS_3DEXP_Desktop ) | 2026/02/16 | - This HF fixes issue related to 'The following file names entered were invalid, not found, locked or of an incompatible type' warning importing STEP part (or other neutral and non-native formats) and no geometry importing STEP assembly
Reference:BR10000419861
| R2026x_FD01 | HF1.13 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/16 | - This HF fixes issue related to Aggregated shapes are not promoted with their parent physical product after minor revision
Reference:BR10000416306 - This HF fixes issue related to split render command crash when Object tracking is on
| R2026x_FD01 | HF1.4 (SOLIDWORKS_3DEXP_Desktop ) | 2026/02/16 | |
| R2026x_FD01 | HF1.12 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/12 | |
| R2026x_FD01 | HF1.11 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/09 | - This HF fixes issue Analytics case fails to launch the on updated 26x FD01 station post migration
| 3DEXPERIENCE R2026x GA |
| R2026x_GA | HF0.26 (HF_NativeApps_3DEXP_Cloud ) | 2026/02/04 | - This HF fixes issue Import 3DXML "Error Importing a data Briefcase: Internal error: collected error"
Reference: BR10000418562
| R2026x_GA | HF0.25 (HF_NativeApps_3DEXP_Cloud ) | 2026/01/29 | - This HF fixes issue Title of the FBX file on the 3DEXPERIENCE remains "Environment" for every import.
Reference: BR10000415979
| R2026x_GA | HF0.24 (HF_NativeApps_3DEXP_Cloud ) | 2026/01/23 | - This HF fixes 3dxml import on cloud MLCDegradation issue
Reference:BR10000418139
| R2026x_GA | HF0.22 (HF_NativeApps_3DEXP_Cloud ) | 2026/01/16 | - This HF fixes issue PPO tries to remove all the replaced/intermediate entities that were generated in 3DSpace including the inserted replacements
| R2026x_GA | HF0.23 (HF_NativeApps_3DEXP_Cloud ) | 2026/01/15 | |
| R2026x_GA | HF0.21 (HF_NativeApps_3DEXP_Cloud ) | 2026/01/13 | |
| R2026x_GA | HF0.20 (HF_NativeApps_3DEXP_Cloud ) | 2026/01/08 | This HF fixes issue related to Missing templates in CS after Data Setup modifications Reference:BR10000406814 This HF fixes issues related to Update of Drawing leads to 3DEXPERIENCE freeze Reference:BR10000410498 This HF fixes error related to VisualScripting | Duplicate buttons is not working anymore Reference:BR10000416989
| R2026x_GA | HF0.3 (SOLIDWORKS_3DEXP_Elec_C) HF0.5 (HF_XCADDesignConnectors ) | 2026/01/06 | - This HF fixes issues related to unexpected behavior (e.g. Crash / Error message )using Replace by Revision to replace an old revision with a newer revision
Reference:BR10000415087 |
| R2026x_GA | HF0.2 (ENOVIA_DerivedFormatConverter)
HF0.19 (HF_NativeApps_3DEXP_Cloud ) | 2026/01/01 | |
| R2026x_GA | HF0.18 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/22 | |
| R2026x_GA | HF0.17 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/19 | - This HF fixes issue related to Core Dump When Predicting the Field Without Loading Results.
- This HF fixes issue related to Model Assessment fails to load if you trained on fields that do not exist in DOE result
| R2026x_GA | HF0.16 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/17 | |
| R2026x_GA | HF0.12 (SOLIDWORKS_3DEXP_Desktop ) | 2025/12/15 | |
| R2026x_GA | HF0.4 (HF_XCADDesignConnectors ) | 2025/12/12 | - This HF fixes issue with Save button unavailable (blocked) within 'Save to 3DEXPERIENCE' Window
Reference:BR10000413542 - This HF fixes issue with Edited Description Property Not Retained After Saving from SOLIDWORKS
Reference:BR10000413853 - This HF fixes issue when saving virtual subassemblies to platform, relationships with child components are missing
Reference:BR10000415744
| R2026x_GA | HF0.11 (SOLIDWORKS_3DEXP_Desktop ) | 2025/12/12 | - This HF fixes issue with Replace by Revision to replace an old revision with a newer revision
| R2026x_GA | HF0.15 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/12 | - This HF fixes issue with Abend during PDF export of specific drawing
Reference:BR10000414926
| R2026x_GA | HF0.10 (CollaborationforMicrosoftClient) | 2025/12/10 | - This HF fixes issue with Validate resource pop-up is shown
Reference: BR10000406051
| R2026x_GA | HF0.10 (SOLIDWORKS_3DEXP_Desktop ) | 2025/12/10 | - This HF fixes issue while saving virtual subassemblies to platform, relationships with child components are missing
Reference: BR10000415744 - This HF fixes issue with Save button unavailable (blocked) within 'Save to 3DEXPERIENCE' Window
Reference: BR10000413542
| R2026x_GA | HF0.14 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/06 | - This HF fixes issue related to Roughing :no engagements from outside.
- This HF fixes issue related to Machining Crash.
- This HF fixes issue related to different result with import of Sandvik cutter with or without new reference creation request.
- This HF fixes issue related to Activities Process View - Crash.
- This HF fixes issue related to modification of Locked MO's.
- This HF fixes issue related to Impossible to use ICAMFoundation.
- This HF fixes issue related to 3DEXPERIENCE session becomes unstable when switch and play with simulation option.
| R2026x_GA | HF0.9 (SOLIDWORKS_3DEXP_Desktop ) | 2025/12/05 | This HF fixes connection issues in offline mode while launching SOLIDWORKS Connected Ultimate. Reference:BR10000410518 This HF fixes issue of component already saved to 3DEXPERIENCE appears as not saved to 3DEXPERIENCE when root assembly is opened from 3DEXPERIENCE Reference:BR10000413507
| R2026x_GA | HF0.13 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/05 | |
| R2026x_GA | HF0.12 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/03 | |
| R2026x_GA | HF0.8 (SOLIDWORKS_3DEXP_Desktop ) | 2025/12/03 | |
| R2026x_GA | HF0.11 (HF_NativeApps_3DEXP_Cloud ) | 2025/12/02 | - This HF fixes issue related to Execution of batch query on dedicated 3DSpace server - ability given to set "ApplicationtType" using CAA api
| R2026x_GA | HF0.10 (HF_NativeApps_3DEXP_Cloud ) | 2025/11/28 | |
| R2026x_GA | HF0.9 (HF_NativeApps_3DEXP_Cloud ) | 2025/11/27 | |
| R2026x_GA | HF 0.3 (HF_XCADDesignConnectors ) | 2025/11/21 | - This HF improves the stability of Design with SOLIDWORKS connecting to 3DEXPERIENCE
| R2026x_GA | HF0.7 (HF_NativeApps_3DEXP_Cloud )
| 2025/11/21 | - This HF fixes issue related to FBDI batch does not leverage VM MetadataBatch when exists
