- Automatically generate alternate toolpath strategies and parameters using AI, enabling NC programmers to significantly reduce machining time during roughing operations. - Improve usability with a compare toolpath function to easily evaluate modifications between releases or when adjusting key parameters. - Support shop floor operators with flexible, easy-to-customize NC documentation tailored to their needs. - Simplify the selection of bottom and top surfaces while adding circular motion, increasing flexibility and efficiency in sequential axial operations.
User Experience Value
- Make cutting tool selection easier by enabling searches based on history or measured geometries, streamlining the process for users.
Support shop floor operator by delivering a NC Documentation that is flexible and easy to customize.
Increase usability with compare toolpath function to evaluate modifications between releases and while changing key parameters.
Simplify cutting tool selection by enabling search with history or by filling measured geometries.
Powered by AI - automatic generation of alternate toolpath strategies and parameters enables NC programmers to minimize the machining time in roughing operations
Increase programming flexibility with the introduction of surface creation by extending existing surfaces and avoid back and forth with CAD design. Increase flexibility and efficiency of sequential axial operation simplifying selection of bottom and top and adding circular motion.
