VBA: How to assign a different global variable value to each configuration and then export driven dimensions?
I am trying to automate a parametric sketch in SolidWorks using VBA.
I have:
- a global variable called `da`
- many configurations such as `da_0`, `da_1`, `da_2`, etc.
- sketch dimensions driven by equations that depend on `da`
What I want is:
1. create or loop through configurations
2. assign a different value of `da` to each configuration
3. rebuild
4. export driven dimensions for each configuration to CSV
The problem is that I can create the configurations, but when I try to set `da` by VBA, the value does not change. The sketch stays at the same state.
For example, in the Equation Manager the actual equation remains something like:
```text
"da" = 6.00
even though the macro is trying to set a different value.
I tried using `SetEquationAndConfigurationOption` with `swSpecifyConfigurations`, but the assigned value still does not become configuration-specific in the way I need.
Minimal snippet:
```vb
cfgNames = Array(cfgName)
eqnText = Chr\\\$(34) & "da" & Chr\\\$(34) & "= " & NumTxt(daValue)
swEqnMgr.SetEquationAndConfigurationOption gvIndex, eqnText, SW_SPECIFY_CONFIGS, cfgNames
Part.ShowConfiguration2 cfgName
Part.EditRebuild3
Part.ForceRebuild3 False
Questions:
1. What is the correct VBA/API pattern to assign a different global-variable value per configuration?
2. Is a global variable the wrong thing to drive here, and should I instead drive a dimension directly per configuration?
3. Once the configurations are valid, what is the best way to export driven dimensions for all configurations via VBA?
Any SolidWorks API example for configuration-specific global variables would help.
