Sheet Metal Gauge Tables
When using Sheet Metal Gauge Tables, when I am creating sheet metal parts with Edge Flanges, is there a way for Solidworks to default to the proper radius and bend deduction for different angles?
For example, if my material thickness is .060" stainless, I draw an Edge Flange that is 90°, the Gauge Table that I have set up with my tooling will have a 0.133" Radius (which, in the Flange Parameters I have "Use gauge table" checked) and the Bend Deduction is 0.131", everything works out great. Now, if I create another Edge Flange that is 45°, my Gauge Table is set up with a 0.252" Radius and a Bend Deduction of .038"... the Bend Deduction works out just fine but do I need to use the drop-down box and manually choose the correct Radius???
In my thought process, I have assumed that it would default, based on the Gauge Table, to the proper Radius for the given Edge-Flange angle... or have I assumed wrong?
Thanks in advance.
