Severe issue with 2d Cabinet Layout
I am experiencing technical issues with SolidWorks Electrical.
Unable to insert 2D Footprints (Cabinet Layout) I cannot insert any manufacturer parts from the component tree into a 2D Cabinet Layout drawing.
Symptoms:
When dragging a component (e.g., Fuse, Terminal) to the drawing, nothing is inserted. The software does not even generate a generic bounding box (rectangle), even though the manufacturer part has defined dimensions (Width/Height/Depth).
Verified:
The drawing type is correctly set to "Cabinet Layout".
Manufacturer parts have correct physical dimensions.
Coordinate system is correct (near 0,0).
Manual Copy/Paste of existing graphical entities works fine on the sheet.
Here is the archive with Logs from Solidworks Rx
This is the post №2 (this was the first one)
