I need some help altering a MACRO.
I have almost zero experience in making macros.
I found this:
Sub main()
Dim swDrawModel As SldWorks.ModelDoc2
Dim swDraw As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim nErrors As Long
Dim nWarnings As Long
Dim Revision As String
Set swDrawModel = swApp.ActiveDoc
If swDrawModel Is Nothing Then
MsgBox "There is no active drawing document"
Exit Sub
End If
If swDrawModel.GetType <> swDocDRAWING Then
MsgBox "Open a drawing first and then TRY again!"
Exit Sub
End If
Set swDraw = swDrawModel
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
If swModel.GetPathName = "" Then
MsgBox "Insert a View first and then TRY again!"
Exit Sub
End If
Revision = swModel.GetCustomInfoValue("", "Revision")
If Revision = "" Then
Revision = ""
End If
Prop = ("Rev_")
Prop = ""
End If
swDraw.SaveAs3 Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) & Prop & Revision & ".PDF", 0, 0
End SubAs I understand it, swDraw.SaveAs3 Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) & Prop & Revision & ".PDF", 0, 0 is the command to find and alter the file with the revision at the end of the filename, but I cannot find the code that tells where to save the PDF.
Can anyone help me out?
Thanks.
