I downloaded the codestack dxf file export for assemblies. It worked great for the first couple of times I used it.
My models utilize Global Variables at the top level. I use these top level models as a project template, but using pack n go's, then find and replace the naming convention.
After doing this a couple of times, the macro now fails and will not complete.
Any ideas or insight would be greatly appreciated.
The code below:
'Copyright(C) 2025 Xarial Pty Limited
'Reference: https://www.codestack.net/solidworks-api/document/sheet-metal/export-all-flat-patterns/?utm_source=chatgpt.com
'License: https://www.codestack.net/license/
Enum SheetMetalOptions_e
ExportFlatPatternGeometry = 1
IncludeHiddenEdges = 2
ExportBendLines = 4
IncludeSketches = 8
MergeCoplanarFaces = 16
ExportLibraryFeatures = 32
ExportFormingTools = 64
ExportBoundingBox = 2048
End Enum
Const SKIP_EXISTING_FILES As Boolean = False
Const OPEN_APP_PATH As String = "" 'Path to the application to open the file (e.g. eDrawings), empty string to not open the file, * to open with default application
Const OUT_NAME_TEMPLATE As String = "DXFs\\<_FileName_>_<_FeatureName_>_<_ConfName_>_<\\\$CLPRP:Description>.dxf"
Const FLAT_PATTERN_OPTIONS As Integer = SheetMetalOptions_e.ExportBendLines + SheetMetalOptions_e.ExportFlatPatternGeometry
Sub main()
try_:
On Error GoTo catch_
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
Err.Raise vbError, "", "Please open assembly or part document"
End If
If swModel.GetType() = swDocumentTypes_e.swDocASSEMBLY Then
Dim swAssy As SldWorks.AssemblyDoc
Set swAssy = swModel
swAssy.ResolveAllLightWeightComponents True
Dim vComps As Variant
vComps = GetDistinctSheetMetalComponents(swAssy)
Dim i As Integer
For i = 0 To UBound(vComps)
Dim swComp As SldWorks.Component2
Set swComp = vComps(i)
ProcessSheetMetalModel swAssy, swComp.GetModelDoc2(), swComp.ReferencedConfiguration
Next
ElseIf swModel.GetType() = swDocumentTypes_e.swDocPART Then
Dim swPart As SldWorks.PartDoc
Set swPart = swApp.ActiveDoc
ProcessSheetMetalModel swPart, swPart, swPart.ConfigurationManager.ActiveConfiguration.Name
Else
Err.Raise vbError, "", "Only assembly and part documents are supported"
End If
swApp.SendMsgToUser2 "Operation completed", swMessageBoxIcon_e.swMbInformation, swMessageBoxBtn_e.swMbOk
GoTo finally_
catch_:
swApp.SendMsgToUser2 Err.Description, swMessageBoxIcon_e.swMbStop, swMessageBoxBtn_e.swMbOk
finally_:
End Sub
Function GetDistinctSheetMetalComponents(assy As SldWorks.AssemblyDoc) As Variant
vComps = assy.GetComponents(False)
Dim i As Integer
Dim swSheetMetalComps() As SldWorks.Component2
If False = swComp.IsSuppressed() Then
If Not ContainsComponent(swSheetMetalComps, swComp) Then
If IsSheetMetalComponent(swComp) Then
If (Not swSheetMetalComps) = -1 Then
ReDim swSheetMetalComps(0)
Else
ReDim Preserve swSheetMetalComps(UBound(swSheetMetalComps) + 1)
End If
Set swSheetMetalComps(UBound(swSheetMetalComps)) = swComp
End If
End If
End If
Next
GetDistinctSheetMetalComponents = Empty
Else
GetDistinctSheetMetalComponents = swSheetMetalComps
End If
End Function
Function IsSheetMetalComponent(comp As SldWorks.Component2) As Boolean
Dim vBodies As Variant
vBodies = comp.GetBodies3(swBodyType_e.swSolidBody, Empty)
If Not IsEmpty(vBodies) Then
Dim i As Integer
For i = 0 To UBound(vBodies)
Dim swBody As SldWorks.Body2
Set swBody = vBodies(i)
If False <> swBody.IsSheetMetal() Then
IsSheetMetalComponent = True
Exit Function
End If
Next
End If
IsSheetMetalComponent = False
End Function
Function ContainsComponent(comps As Variant, swComp As SldWorks.Component2) As Boolean
Dim i As Integer
For i = 0 To UBound(comps)
Dim swThisComp As SldWorks.Component2
Set swThisComp = comps(i)
If swThisComp.GetPathName() = swComp.GetPathName() And swThisComp.ReferencedConfiguration = swComp.ReferencedConfiguration Then
ContainsComponent = True
Exit Function
End If
Next
ContainsComponent = False
End Function
Function ComposeOutFileName(template As String, rootModel As SldWorks.ModelDoc2, sheetMetalModel As SldWorks.ModelDoc2, conf As String, flatPatternFeat As SldWorks.Feature, cutListFeat As SldWorks.Feature) As String
Dim regEx As Object
Set regEx = CreateObject("VBScript.RegExp")
regEx.Global = True
regEx.IgnoreCase = True
regEx.Pattern = "<[^>]*>"
Dim regExMatches As Object
Set regExMatches = regEx.Execute(template)
Dim i As Integer
Dim outFileName As String
outFileName = template
For i = regExMatches.Count - 1 To 0 Step -1
Dim regExMatch As Object
Set regExMatch = regExMatches.Item(i)
Dim tokenName As String
tokenName = Mid(regExMatch.Value, 2, Len(regExMatch.Value) - 2)
outFileName = Left(outFileName, regExMatch.FirstIndex) & ResolveToken(tokenName, rootModel, sheetMetalModel, conf, flatPatternFeat, cutListFeat) & Right(outFileName, Len(outFileName) - (regExMatch.FirstIndex + regExMatch.Length))
Next
ComposeOutFileName = ReplaceInvalidPathSymbols(GetFullPath(rootModel, outFileName))
End Function
Function ReplaceInvalidPathSymbols(path As String) As String
Const REPLACE_SYMB As String = "_"
Dim res As String
res = Right(path, Len(path) - Len("X:\\"))
Dim drive As String
drive = Left(path, Len("X:\\"))
Dim invalidSymbols As Variant
invalidSymbols = Array("/", ":", "*", "?", """", "<", ">", "|")
Dim i As Integer
For i = 0 To UBound(invalidSymbols)
Dim invalidSymb As String
invalidSymb = CStr(invalidSymbols(i))
res = Replace(res, invalidSymb, REPLACE_SYMB)
Next
ReplaceInvalidPathSymbols = drive + res
End Function
Function ResolveToken(token As String, rootModel As SldWorks.ModelDoc2, sheetMetalModel As SldWorks.ModelDoc2, conf As String, flatPatternFeat As SldWorks.Feature, cutListFeat As SldWorks.Feature) As String
Const FILE_NAME_TOKEN As String = "_FileName_"
Const ASSM_FILE_NAME_TOKEN As String = "_AssmFileName_"
Const FEAT_NAME_TOKEN As String = "_FeatureName_"
Const CONF_NAME_TOKEN As String = "_ConfName_"
Const PRP_TOKEN As String = "\\\$PRP:"
Const CUT_LIST_PRP_TOKEN As String = "\\\$CLPRP:"
Const ASM_PRP_TOKEN As String = "\\\$ASSMPRP:"
Select Case LCase(token)
Case LCase(FILE_NAME_TOKEN)
ResolveToken = GetFileNameWithoutExtension(sheetMetalModel.GetPathName)
Case LCase(FEAT_NAME_TOKEN)
ResolveToken = flatPatternFeat.Name
Case LCase(CONF_NAME_TOKEN)
ResolveToken = conf
Case LCase(ASSM_FILE_NAME_TOKEN)
If rootModel.GetPathName() = "" Then
Err.Raise vbError, "", "Assembly must be saved to use " & ASSM_FILE_NAME_TOKEN
End If
ResolveToken = GetFileNameWithoutExtension(rootModel.GetPathName())
Case Else
Dim prpName As String
If Left(token, Len(PRP_TOKEN)) = PRP_TOKEN Then
prpName = Right(token, Len(token) - Len(PRP_TOKEN))
ResolveToken = GetModelPropertyValue(sheetMetalModel, conf, prpName)
ElseIf Left(token, Len(ASM_PRP_TOKEN)) = ASM_PRP_TOKEN Then
prpName = Right(token, Len(token) - Len(ASM_PRP_TOKEN))
ResolveToken = GetModelPropertyValue(rootModel, rootModel.ConfigurationManager.ActiveConfiguration.Name, prpName)
ElseIf Left(token, Len(CUT_LIST_PRP_TOKEN)) = CUT_LIST_PRP_TOKEN Then
prpName = Right(token, Len(token) - Len(CUT_LIST_PRP_TOKEN))
ResolveToken = GetPropertyValue(cutListFeat.CustomPropertyManager, prpName)
Else
Err.Raise vbError, "", "Unrecognized token: " & token
End If
End Select
End Function
Function GetModelPropertyValue(model As SldWorks.ModelDoc2, confName As String, prpName As String) As String
Dim prpVal As String
Dim swCustPrpMgr As SldWorks.CustomPropertyManager
Set swCustPrpMgr = model.Extension.CustomPropertyManager(confName)
prpVal = GetPropertyValue(swCustPrpMgr, prpName)
If prpVal = "" Then
Set swCustPrpMgr = model.Extension.CustomPropertyManager("")
End If
GetModelPropertyValue = prpVal
End Function
Function GetPropertyValue(custPrpMgr As SldWorks.CustomPropertyManager, prpName As String) As String
Dim resVal As String
custPrpMgr.Get2 prpName, "", resVal
GetPropertyValue = resVal
End Function
Function GetFileNameWithoutExtension(path As String) As String
GetFileNameWithoutExtension = Mid(path, InStrRev(path, "\\") + 1, InStrRev(path, ".") - InStrRev(path, "\\") - 1)
End Function
Function GetCutListFeatures(model As SldWorks.ModelDoc2) As Variant
GetCutListFeatures = GetFeaturesByType(model, "CutListFolder")
End Function
Function GetFlatPatternFeatures(model As SldWorks.ModelDoc2) As Variant
GetFlatPatternFeatures = GetFeaturesByType(model, "FlatPattern")
End Function
Sub ProcessSheetMetalModel(rootModel As SldWorks.ModelDoc2, sheetMetalModel As SldWorks.ModelDoc2, conf As String)
Dim activeConfName As String
Dim error As ErrObject
try_:
activeConfName = sheetMetalModel.ConfigurationManager.ActiveConfiguration.Name
If LCase(activeConfName) <> LCase(conf) Then
If False = sheetMetalModel.ShowConfiguration2(conf) Then
Err.Raise vbError, "", "Failed to activate configuration"
End If
End If
Dim vCutListFeats As Variant
vCutListFeats = GetCutListFeatures(sheetMetalModel)
If Not IsEmpty(vCutListFeats) Then
Dim vFlatPatternFeats As Variant
vFlatPatternFeats = GetFlatPatternFeatures(sheetMetalModel)
If Not IsEmpty(vFlatPatternFeats) Then
Dim swProcessedCutListsFeats() As SldWorks.Feature
Dim i As Integer
For i = 0 To UBound(vFlatPatternFeats)
Dim swFlatPatternFeat As SldWorks.Feature
Dim swFlatPattern As SldWorks.FlatPatternFeatureData
Set swFlatPatternFeat = vFlatPatternFeats(i)
Set swFlatPattern = swFlatPatternFeat.GetDefinition
Dim swFixedEnt As SldWorks.Entity
Set swFixedEnt = swFlatPattern.FixedFace2
If TypeOf swFixedEnt Is SldWorks.Face2 Then
Dim swFixedFace As SldWorks.Face2
Set swFixedFace = swFixedEnt
Set swBody = swFixedFace.GetBody
ElseIf TypeOf swFixedEnt Is SldWorks.Edge Then
Dim swFixedEdge As SldWorks.Edge
Set swFixedEdge = swFixedEnt
Set swBody = swFixedEdge.GetBody
ElseIf TypeOf swFixedEnt Is SldWorks.Vertex Then
Dim swFixedVert As SldWorks.Vertex
Set swFixedVert = swFixedEnt
Set swBody = swFixedVert.GetBody
End If
Dim swCutListFeat As SldWorks.Feature
Set swCutListFeat = FindCutListFeature(vCutListFeats, swBody)
If Not swCutListFeat Is Nothing Then
Dim isUnique As Boolean
If (Not swProcessedCutListsFeats) = -1 Then
isUnique = True
ElseIf Not ContainsSwObject(swProcessedCutListsFeats, swCutListFeat) Then
isUnique = True
Else
isUnique = False
End If
If isUnique Then
ReDim swProcessedCutListsFeats(0)
Else
ReDim Preserve swProcessedCutListsFeats(UBound(swProcessedCutListsFeats) + 1)
End If
Set swProcessedCutListsFeats(UBound(swProcessedCutListsFeats)) = swCutListFeat
outFileName = ComposeOutFileName(OUT_NAME_TEMPLATE, rootModel, sheetMetalModel, conf, swFlatPatternFeat, swCutListFeat)
If Not SKIP_EXISTING_FILES Or Not FileExists(outFileName) Then
ExportFlatPattern sheetMetalModel, swFlatPatternFeat, outFileName, FLAT_PATTERN_OPTIONS
If OPEN_APP_PATH <> "" Then
OpenFile outFileName
End If
End If
End If
Else
Err.Raise vbError, "", "Failed to find cut-list for flat pattern " & swFlatPatternFeat.Name
End If
Next
Else
Err.Raise vbError, "", "No flat pattern features found"
End If
Else
Err.Raise vbError, "", "No cut-list items found"
End If
GoTo finally_
catch_:
Set error = Err
finally_:
sheetMetalModel.ShowConfiguration2 activeConfName
If Not error Is Nothing Then
Err.Raise error.Number, error.Source, error.Description, error.HelpFile, error.HelpContext
End If
End Sub
Function FileExists(filePath As String) As Boolean
FileExists = Dir(filePath) <> ""
End Function
Function FindCutListFeature(vCutListFeats As Variant, body As SldWorks.Body2) As SldWorks.Feature
Dim i As Integer
For i = 0 To UBound(vCutListFeats)
Set swCutListFeat = vCutListFeats(i)
Dim swBodyFolder As SldWorks.BodyFolder
Set swBodyFolder = swCutListFeat.GetSpecificFeature2
vBodies = swBodyFolder.GetBodies
If ContainsSwObject(vBodies, body) Then
Set FindCutListFeature = swCutListFeat
End If
Next
End Function
Function ContainsSwObject(vArr As Variant, obj As Object) As Boolean
If Not IsEmpty(vArr) Then
Dim i As Integer
For i = 0 To UBound(vArr)
Dim swObj As Object
Set swObj = vArr(i)
If swApp.IsSame(swObj, obj) = swObjectEquality.swObjectSame Then
ContainsSwObject = True
Exit Function
End If
Next
End If
ContainsSwObject = False
End Function
Function GetFeaturesByType(model As SldWorks.ModelDoc2, typeName As String) As Variant
Dim swFeats() As SldWorks.Feature
Dim swFeat As SldWorks.Feature
Set swFeat = model.FirstFeature
Do While Not swFeat Is Nothing
If typeName = "CutListFolder" And swFeat.GetTypeName2() = "SolidBodyFolder" Then
Set swBodyFolder = swFeat.GetSpecificFeature2
swBodyFolder.UpdateCutList
End If
ProcessFeature swFeat, swFeats, typeName
Set swFeat = swFeat.GetNextFeature
Loop
If (Not swFeats) = -1 Then
GetFeaturesByType = Empty
Else
GetFeaturesByType = swFeats
End If
End Function
Sub ProcessFeature(thisFeat As SldWorks.Feature, featsArr() As SldWorks.Feature, typeName As String)
If thisFeat.GetTypeName2() = typeName Then
If (Not featsArr) = -1 Then
ReDim featsArr(0)
Set featsArr(0) = thisFeat
Else
Dim i As Integer
For i = 0 To UBound(featsArr)
If swApp.IsSame(featsArr(i), thisFeat) = swObjectEquality.swObjectSame Then
Exit Sub
End If
Next
ReDim Preserve featsArr(UBound(featsArr) + 1)
Set featsArr(UBound(featsArr)) = thisFeat
End If
End If
Dim swSubFeat As SldWorks.Feature
Set swSubFeat = thisFeat.GetFirstSubFeature
While Not swSubFeat Is Nothing
ProcessFeature swSubFeat, featsArr, typeName
Set swSubFeat = swSubFeat.GetNextSubFeature
Wend
End Sub
Sub ExportFlatPattern(part As SldWorks.PartDoc, flatPattern As SldWorks.Feature, outFilePath As String, opts As SheetMetalOptions_e)
Set swModel = part
Dim hide As Boolean
try_:
If False = swModel.Visible Then
hide = True
swModel.Visible = True
End If
swApp.ActivateDoc3 swModel.GetPathName(), False, swRebuildOnActivation_e.swDontRebuildActiveDoc, 0
swModel.FeatureManager.EnableFeatureTree = False
swModel.FeatureManager.EnableFeatureTreeWindow = False
swModel.ActiveView.EnableGraphicsUpdate = False
Dim outDir As String
outDir = Left(outFilePath, InStrRev(outFilePath, "\\"))
CreateDirectories outDir
Dim modelPath As String
modelPath = part.GetPathName
If modelPath = "" Then
Err.Raise vbError, "", "Part document must be saved"
End If
If False <> flatPattern.Select2(False, -1) Then
If False = part.ExportToDWG2(outFilePath, modelPath, swExportToDWG_e.swExportToDWG_ExportSheetMetal, True, Empty, False, False, opts, Empty) Then
Err.Raise vbError, "", "Failed to export flat pattern"
End If
Else
Err.Raise vbError, "", "Failed to select flat-pattern"
End If
GoTo finally_
catch_:
Set error = Err
finally_:
swModel.FeatureManager.EnableFeatureTree = True
swModel.FeatureManager.EnableFeatureTreeWindow = True
swModel.ActiveView.EnableGraphicsUpdate = True
If hide Then
swApp.CloseDoc swModel.GetTitle
End If
End If
End Sub
Sub OpenFile(filePath As String)
If OPEN_APP_PATH = "*" Then
Shell """" & filePath & """"
Else
Shell """" & OPEN_APP_PATH & """" & " " & """" & filePath & """"
End If
End Sub
Sub CreateDirectories(path As String)
Dim fso As Object
Set fso = CreateObject("Scripting.FileSystemObject")
If fso.FolderExists(path) Then
Exit Sub
End If
CreateDirectories fso.GetParentFolderName(path)
fso.CreateFolder path
End Sub
Function GetFullPath(model As SldWorks.ModelDoc2, path As String)
GetFullPath = path
If IsPathRelative(path) Then
If Left(path, 1) <> "\\" Then
path = "\\" & path
End If
Dim modelDir As String
modelPath = model.GetPathName
modelDir = Left(modelPath, InStrRev(modelPath, "\\") - 1)
GetFullPath = modelDir & path
End If
End Function
Function IsPathRelative(path As String)
IsPathRelative = Mid(path, 2, 1) <> ":" And Not IsPathUnc(path)
End Function
Function IsPathUnc(path As String)
IsPathUnc = Left(path, 2) = "\\\\"
End Function
