What is the process to merge two independent PDM vaults on three servers into two servers with two vaults?
Current configuration:
Server A1 – Archive
PDM Vault A (PDM Pro Vault)
Server A2 - SQL
SQL Instance A (SQL Standard)
SQL Vault A DB
SQL ConisioMaster A DB
Server B1 - Archive
PDM Vault B (PDM Standard vault)
SQL Instance B (SQL Express)
SQL Vault B DB
SQL ConisioMaster B DB
End goal configuration:
Server A1 - Archive
Server A2 - SQL
SQL Vault A DB
SQL Vault B DB
The SQL merge appears to be pretty straightforward – restore the Vault B DB to SQL server A and add a row to the FileVaults table in the ConisioMaster DB. How can the Archive Server settings be merged into one server? On Archive Server A could I create a new vault using the same name as the server B vault, then just replace the new vaults empty root folder with a backup of the Vault B root folder?
For the Vault B clients I think that I’d remove the vault views before staring the migration, then create new vault views once the Vault B was moved to server A.
Once everything is working I’d upgrade the PDM Standard vault to PDM Pro.
Thanks
Jonathan
