Get Sketch Point Coordinates in Relation to Custom Coord System API
I'm working on some code where I am filtering sketches that are designated for my CNC, looping through the sketch segments, obtaining sketch points from each segment, and needing to create a list of these coordinates so that I can recreate them later in the program in my nesting software.
Following along with the API examples, I am able to get the correct coordinates comparing against the model transform, but the issue is that I am needing this in relation to a custom coordinate system I've placed in the model. Based on the model, the orientation can change file to file on which face of the part needs to be facing "up". If that all makes sense.
I am able to get the transform object for the coordinate system using the API help, but none of the coordinates are coming out correct. Can someone point me in the right direction of where I am hosing this up? This is my first go 'round with transforms, I have been trying to research online from explanations people have provided, but it is a little difficult to wrap my head around...
Any help would be greatly appreciated. Thanks!
Public Sub ConvertUserUnits(ByRef dPt() As Double, ByRef swModel As ModelDoc2)
    If swModel Is Nothing Then Exit Sub
    If dPt.Length < 3 Then Exit Sub
    Dim swUserUnits As UserUnit = swModel.GetUserUnit(swUserUnitsType_e.swLengthUnit)
    If swUserUnits IsNot Nothing Then
        Dim dConvFactor As Double = swUserUnits.GetConversionFactor
        dPt(0) = dPt(0) * dConvFactor
        dPt(1) = dPt(1) * dConvFactor
        dPt(2) = dPt(2) * dConvFactor
    End If
End Sub
Public Function TransformSketchPointToCncSpace(ByRef swApp As SldWorks, ByRef swModel As ModelDoc2, ByRef swSketch As Sketch, ByRef swSketchPt As SketchPoint) As MathPoint
   Dim TheAnswer As MathPoint = Nothing
   Try
           TheAnswer = Nothing
           Return TheAnswer
           Exit Function
       End If
       If swSketch Is Nothing Then
           TheAnswer = Nothing
           Return TheAnswer
           Exit Function
       End If
       If swSketchPt Is Nothing Then
           TheAnswer = Nothing
           Return TheAnswer
           Exit Function
       End If
       Dim swMathUtil As MathUtility = Nothing
    Dim dPt(2) As Double
    Dim oPt As Object
    Dim swCncTransform As MathTransform = Nothing
    Dim swMathPt As MathPoint = Nothing
    Dim sCoordName As String = ""
    dPt(0) = swSketchPt.X
    dPt(1) = swSketchPt.Y
    dPt(2) = swSketchPt.Z
    oPt = dPt
    swMathUtil = swApp.GetMathUtility
    sCoordName = GetCncCoordSysName(swModel)
    If sCoordName = "" Then sCoordName = swModel.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swFileSaveAsCoordinateSystem)
    swCncTransform = swModel.Extension.GetCoordinateSystemTransformByName(sCoordName)
    If swCncTransform IsNot Nothing Then
          swCncTransform = TryCast(swCncTransform.Inverse, MathTransform)
          swMathPt = TryCast(swMathUtil.CreatePoint(oPt), MathPoint)
          If swMathPt IsNot Nothing Then
             TheAnswer = TryCast(swMathPt.MultiplyTransform(swCncTransform), MathPoint)
          End If
    End If
   Catch ex As Exception
       Debug.WriteLine(ex)
   End Try
   Return TheAnswer
End Function
Public Sub ProcessSketchLine(ByRef swApp As SldWorks, ByRef swModel As ModelDoc2, ByRef swSketch As Sketch, ByRef swSketchLine As SketchLine)
   Try
       If swApp Is Nothing Then Exit Sub
       If swSketch Is Nothing Then Exit Sub
       If swSketchLine Is Nothing Then Exit Sub
       Dim swStartPt As SketchPoint = TryCast(swSketchLine.GetStartPoint2, SketchPoint)
       If swStartPt Is Nothing Then Exit Sub
       Dim swEndPt As SketchPoint = TryCast(swSketchLine.GetEndPoint2, SketchPoint)
       If swEndPt Is Nothing Then Exit Sub
       'Dim swStartCncPt As MathPoint = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swStartPt)
       'Dim swEndCncPt As MathPoint = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swEndPt)
       Dim swStartCncPt As MathPoint = TransformSketchPointToCncSpace(swApp, swModel, swSketch, swStartPt)
       Dim swEndCncPt As MathPoint = TransformSketchPointToCncSpace(swApp, swModel, swSketch, swEndPt)
       If swStartCncPt IsNot Nothing And swEndCncPt IsNot Nothing Then
           dPt(0) = swStartPt.X
           dPt(1) = swStartPt.Y
           dPt(2) = swStartPt.Z
           ConvertUserUnits(dPt, swModel)
           AddStringToLog("Converted SketchLine for swStartPt: " + CStr(dPt(0)) + ", " + CStr(dPt(1)) + ", " + CStr(dPt(2)))
           dPt(0) = swEndPt.X
           dPt(1) = swEndPt.Y
           dPt(2) = swEndPt.Z
           AddStringToLog("Converted SketchLine for swEndPt: " + CStr(dPt(0)) + ", " + CStr(dPt(1)) + ", " + CStr(dPt(2)))
           dPt(0) = swStartCncPt.ArrayData(0)
           dPt(1) = swStartCncPt.ArrayData(1)
           dPt(2) = swStartCncPt.ArrayData(2)
           AddStringToLog("Converted SketchLine for swStartCncPt: " + CStr(dPt(0)) + ", " + CStr(dPt(1)) + ", " + CStr(dPt(2)))
           dPt(0) = swEndCncPt.ArrayData(0)
           dPt(1) = swEndCncPt.ArrayData(1)
           dPt(2) = swEndCncPt.ArrayData(2)
           AddStringToLog("Converted SketchLine for swEndCncPt: " + CStr(dPt(0)) + ", " + CStr(dPt(1)) + ", " + CStr(dPt(2)))
       End If
       Debug.WriteLine(ex)
   End Try
End Sub
