Converting Sketch Entities onto Drawing with the API
Hello, all!
I'm currently working on a solidworks API macro.  In our current process, special geometry on sheet-metal parts for etching and opening pathing is done by creating a sketch of the desired cut/etch, and then later, before saving to a DXF, creating the layer "ETCH" or "OPEN", selecting the sketch from the drawing view feature tree, and using "convert entities".
Thus, certain sketches are on the "ETCH" layer, and others are on the "OPEN" layer.
In my current code, I can locate the sketches of interest and create the drawing layers, but I can't seem to figure out how to properly select and convert the sketches.  I've tried selecting both the sketch feature and the sketch segments and using SketchUseEdge3 (which returns true, yet doesn't seem to convert entities as the UI does...), as well as trying to simply assign segment.layer, but both have come up short.
Am I targeting the incorrect sketch, somehow?  Can I iterate through the view's feature tree directly in some way, rather than going through the part's features?
Attached is an image of the drawing tree, noting the sketches I want to target and put onto two different DXF layers.  Simplified code is below.
Set swApp = CreateObject("SldWorks.Application")
Debug.Print "Starting right nooooowwww"
For i = 1 To pathList.Count
   Set swModel = swApp.OpenDoc(pathList(i), 1) 'Can I force-open a drawing of the doc if I make the integer 3?
   'Set swDraw = swApp.NewDocument("C:\\ProgramData\\SolidWorks\\SOLIDWORKS 2025\\templates\\Drawing.drwdot", 0#, 0#, 0#)
   Set swDraw = swApp.OpenDoc4("C:\\Program Files\\SOLIDWORKS Corp\\SOLIDWORKS\\DXF_Transfer\\SLDDXF.SLDDRW", 3, 0, "", longstatus)
   'Set swDraw = swApp.activateDoc("SLDDXF - Sheet1")
   Set layMgr = swDraw.GetLayerManager
   retInt = layMgr.AddLayer("ETCH", "", RGB(0, 255, 0), 0, 0)
   retInt = layMgr.AddLayer("OPEN", "", RGB(255, 0, 0), 0, 0)
   'place view
   swDraw.ShowConfiguration "Default"
   Set swView = swDraw.CreateFlatPatternViewFromModelView3(pathList(i), "Default", 0, 0, 0, True, False)
   swDraw.ViewZoomtofit2
   Set swView = swDraw.GetFirstView
   Set swView = swView.GetNextView
   Set sktMgr = swModel.SketchManager
   Set swFeat = swModel.FirstFeature
   Do While Not swFeat Is Nothing:
       swFeatName = swFeat.GetTypeName2
       If swFeatName = "ProfileFeature" Or swFeatName = "3DProfileFeature" Then
           sketchTitle = swFeat.Name
           If sketchTitle Like "ETCH_*" Then
               Debug.Print "Found an Etch"
               retInt = layMgr.SetCurrentLayer("ETCH")
               Set swSketch = swFeat.GetSpecificFeature2
               layRet = swSketch.Select2(False, 0)
               Debug.Print layRet
               'swView.Select2 False, 0
               'segList = swSketch.GetSketchSegments
               'Dim j As Integer
               'For j = 0 To UBound(segList)
                '   Set segment = segList(j)
                 '  segment.Layer = "ETCH"
                  ' Debug.Print layRet
               'Next j
               swModel.EditSketch
               layRet = sktMgr.SketchUseEdge3(True, True)
               Debug.Print layRet
           ElseIf sketchTitle Like "OPEN_*" Then
               Debug.Print "Found a Open"
               'retInt = layMgr.SetCurrentLayer("OPEN")
               'layRet = swFeat.Select2(False, 0)
               'swModel.EditSketch
               'layRet = swView.Select2(False, 0)
               'layRet = sktMgr.SketchUseEdge3(False, True)
               'Debug.Print layRet
           End If
       End If
       Set swFeat = swFeat.GetNextFeature
   Loop
