API-set Gauge Tables Require Manual Prompt to Initialize
I've written a macro which does several updates to parts, including ensuring that the latest gauge tables are assigned and control the bend dimensions. However, several parts are resulting with errors in Closed Corners or Flat Patterns. It seems to be a result of the gauge tables not processing fully, because if I edit the multibody Sheet-Metal folder or the Sheet-Metal body feature within it and only hit confirm, I see the Excel gauge table appear briefly, the part regenerates, and then the errors disappear.
sGaugeTblFile = sGaugeTblDir & sPS & sPrefix & sSuffix
' Set multibody sheet metal folder to use gauge table
Set swFeat = swModelExt.GetTemplateSheetMetal
If Not swFeat Is Nothing Then
    Set swSMData = swFeat.GetDefinition
    swSMData.AccessSelections swModel, Nothing
    swSMData.SetUseGaugeTable False, ""
    swSMData.SetUseGaugeTable True, sGaugeTblFile
    Set swCustBend = swSMData.GetCustomBendAllowance
    swCustBend.Type = swBendAllowanceGaugeTable
    Call swSMData.SetCustomBendAllowance(swCustBend)
    bOpSuccess = bOpSuccess * swFeat.ModifyDefinition(swSMData, _
                                                      swModel, _
                                                      Nothing)
End If
' Set individual sheet metal bodies to use gauge table
Set swFeat = swModel.FirstFeature
Do While Not swFeat Is Nothing
    Select Case swFeat.GetTypeName2
        Case "SheetMetal"
            ' Activate use of Gauge Table
            lGaugeTblRet = swSMData.GetUseGaugeTable(bUseGaugeTbl, sOldGaugeTbl)
            If Not bUseGaugeTbl Then
                ' Activate Gauge Table
                swSMData.SetUseGaugeTable True, ""
            End If
            ' Ensure override states
            iErrOut = swSMData.SetOverrideDefaultParameter2(swSheetMetalOverrideDefaultParameters_BendParameters, False)
            iErrOut = swSMData.SetOverrideDefaultParameter2(swSheetMetalOverrideDefaultParameters_BendAllowance, True)
            iErrOut = swSMData.SetOverrideDefaultParameter2(swSheetMetalOverrideDefaultParameters_AutoRelief, False)
            ' Switch to use Gauge Table for Bend Allowance
            If swCustBend.Type <> swBendAllowanceGaugeTable Then
            End If
                                                              swModel, _
                                                              Nothing)
        Case "SMBaseFlange"
            Set swBFData = swFeat.GetDefinition
            swBFData.AccessSelections swModel, Nothing
            bUseGaugeTbl = swBFData.UseGaugeTable
                swBFData.UseGaugeTable = True
            End If
            ' Ensure overrides are off
            With swBFData
                .OverrideDefaultSheetMetalParameters = False
                .OverrideThickness = False
                .OverrideRadius = False
            End With ' swBFData
            bOpSuccess = bOpSuccess * swFeat.ModifyDefinition(swBFData, _
                                                              swModel, _
                                                              Nothing)
        Case "SolidToSheetMetal"
            ' Unknown if anything is needed here
    End Select
    Set swFeat = swFeat.GetNextFeature
Loop
' Setup Thickness
' Note: This does not need to be condition-limited.
'         Thickness will simply remap to the same value.
        Case "SheetMetal"
            ' Placeholder for figuring out how to set gauge at parent level
        Case "SMBaseFlange"
            ' This will work for most parts
            With swBFData
                vThicknesses = .GetTableThicknesses
                .ThicknessTableName = vThicknesses(iGauge)
                vRadii = .GetTableRadii(vThicknesses(iGauge)) ' Note: In METERS
                .TableRadius = vRadii(0) / 0.0254
                    ' Seems our gauge tables only produce one radius
            End With
                                                              swModel, _
                                                              Nothing)
            ' Some parts are created as extrusions and then converted and need special handling
            bOpSuccess = False
            Set swCSFData = swFeat.GetDefinition
    End Select
Loop
