How does this work on the back end? If my PCBC models and current production data are ready, do I need to run PCBC manually and upload the results, or can the dashboard run the calculations automatically?
This question was raised during the live session of GEOVIA CONNECT 25X: Beyond Mine Planning and Design for Caving Operations with @DV and @CL. If you were unable to attend, the session is now available on demand at the link below.
💻 Watch on demand:
Here's the response from @DV ,Under Ground Mining Industry Process Consultant Expert - Dassault Systèmes:
Daniel VILLA
The dashboard is a visualization and analysis tool that consumes data created in PCBC. You still run your scenarios in PCBC, then bring those results into the dashboard for comparison, analysis, and sharing.
The dashboard does not execute PCBC runs; it displays and interacts with the results you import. You can load many scenarios, compare them, analyze actuals versus simulations, and share information across the team without needing Surpac / PCBC on every machine.
Data can be imported manually or through automated processes. Dashboards are customizable, and you can include additional data sources such as seismic or undercut information. If you want to automate scenario runs, you can use macros in Surpac.or the automated workflow using Process Composer for Scenario Simulation.
For further information, please refer to the resources below.
Surpac caving solutions for GEMS users
Caving Solutions In Surpac
Strategic Mine Planning for Caving
Block Caving & Underground Mining
GC25X
