Hi Team
I need support in defining the required orientation of the product. Scenario is below
EBOM is imported as Manufacturing Product; Conveyor and its sections are defined; Mobile storage (Pallet) is defined and storage for the Mobile storage is done; Decision zones are created on the conveyor; Its Assembly on the conveyor pallet so I guess I can use Pack activity to pack Pallet and the components in each decision zone
When I define all required flows and activities, Part orientation on the pallet is not working as intended, instead it shows somewhere in the air and moving when pallet is transferring on the conveyor.
When I change the component orientation using Axis system it is getting changed in Product (EBOM) too.
What is the correct steps to maintain or define part orientation when it is packing with the pallet and conveyor. Sometimes pallet also not oriented with the conveyor, even if we change the orientation in Transfer activity, it is not reflecting. Is there any Env variable need to be set.
Kindly provide the best approach.
Thanks in Advance.
