Wrong validation of ItemFlow direction vs FlowProperty direction on connectors between Block and Port.
I observed an inconsistent and incorrect behavior during model verification when checking connectors between a Part and a Port.
As shown in the attached figure, the tool does not consistently validate the ItemFlow direction against the FlowProperty direction, depending on whether the FlowProperty is defined on a block or on a interface block.
Sub Block 1
  • The ItemFlow is directed from the Part to the port.
  • The corresponding FlowProperty in the block has direction in.
  • Expected: An error should be raised, as the ItemFlow direction contradicts the FlowProperty direction.
  • Actual: No error is reported.
Sub Block 2 with port
  • Same ItemFlow direction scenario.
  • The FlowProperty is defined on if2in.
  • Actual: An error is correctly reported.
Sub Block 2 (NO port)
  • The FlowProperty is defined on Sub Block 2
Some other example show the same problem. It seems that the ItemFlow direction itself is ignored when verifying item flow direction on connectors between a part and Block.
Attached the model used to create the issue.
Tool Version used: Caria | Magic Cyber Systems Engineer 2026 HF1
I would kindly ask you to check further.
Kind Regards,
Francesco Matraxia
