We are implementing a Java plugin with batch/command-line execution to automate the following workflow in CATIA Magic (3DEXPERIENCE Power By):
- Launch CATIA Magic in batch mode
- Login to the 3DEXPERIENCE platform
- Create a project (Update Model)
- Save and commit the project to the server for transition activities
We are following the official documentation for command-line launchers and batch mode:
https://docs.nomagic.com/DEVG/2026x/implementing-command-line-launchers-254437340.html
https://docs.nomagic.com/DEVG/2026x/specifying-batch-mode-program-classpath-and-required-system-properties-254437301.html
Environment Details :
CATIA Magic Version: 2024x (System of Systems Architect)
Operating System: Windows
3DEXPERIENCE Tenant: Private Cloud – R2026x FD01
We evaluated multiple approaches to authenticate to the 3DEXPERIENCE platform from CATIA Magic when launched in batch mode:
1. TeamworkService (Cloud) via CommandLineAction
API: ITeamworkService.login(ServerLoginInfo)
Result: Connection failure
Error indicates inability to resolve/connect to the 3DEXPERIENCE server (
2. TeamworkService (Cloud) via CommandLineActionLauncher :
Result: NullPointerException
Stack trace points to TeamworkOptionsGroup.setMUUserPasswordAndEncrypt() during login
Suggests missing or uninitialized teamwork context in batch mode
3. DSClientProvider via ProjectCommandLineAction
API: DSClientProvider.INSTANCE.connect(UsernamePasswordData)
Result: Plugin not initialized
Error: Local Project not found
Login does not occur because project context is required before plugin execution
4. DSClientProvider via CommandLineAction (Deprecated API)
Result: Successful
Application launches
Login succeeds
Project is created successfully
Issue: DSClientProvider is deprecated, and we want to avoid using unsupported APIs
Main Question
What is the recommended and supported Java API for logging into the 3DEXPERIENCE platform from CATIA Magic in batch/command-line mode?
Specifically:
- Is there a replacement for DSClientProvider for batch login?
- Is there any official documentation or example for 3DEXPERIENCE authentication via Java plugins in command-line execution?
Any guidance, best practices, or references would be greatly appreciated.
