Hello, I have a problem. I want to build a library where I sometimes need elements that should only be included once. The following example illustrates this: I want the user to be able to attach to "mqttcred" only, not to two. Is this possible, or am I misunderstanding something? Secondly, I have a question about the "broker" attribute. How can I ensure that the user redefines it and does not subset it? Because they could easily subset 'broker', and then I would have multiple 'broker' instances in 'mqtt cred', which makes no sense. Maybe it works with assert constraints but jupyter doesn't evaluate those.
library package example{
private import ScalarValues::*;
private import Metaobjects::SemanticMetadata;
part def MQTT_CREDS{
attribute broker:ScalarValues::String;
attribute url:ScalarValues::String;
part def Communication{
part mqtt_creds:MQTT_CREDS;
metadata def <mqqtcred> MData :> SemanticMetadata {
:>> baseType default Communication::mqtt_creds meta SysML::PartUsage;
:>> annotatedElement:SysML::PartUsage;
metadata def <comm> CommData :> SemanticMetadata {
:>> baseType default Communication meta SysML::PartDefinition;
:>> annotatedElement:SysML::PartDefinition;
#comm part def {
#mqqtcred part example{
:>>broker = "testbroker";
:>>url = "testurl";
// but the user still can place multiple mqqtcreds
#comm part def {
:>>url = "testurl";
#mqqtcred part example2{
:>>url = "testurl";
