I'm not sure if this is right place to ask this question. I'm trying to use the TWC Used Project Auto-Update Wizard and script with Cameo 2024xR3 (both SM and EA). I've successfully used this plug-in & script in the past in Cameo 2021x, so I am familiar with the process. Once we transitioned to Cameo 2024xR3 I continually run into errors when trying to run the script.
Examining the cea.log (or csm.log) file, I see the following error that appears multiple times that seems to be preventing the plug-in from executing properly:
WARN  GENERAL - JLink.jar not found in C:\\Cameo_EA_24R3\\plugins\\com.nomagic.magicdraw.twcusageupdater. Check if integration is correct.
This is followed by the error:
ERROR GENERAL - Commandline action com.nomagic.magicdraw.twcusageupdater.UpdateProjectUsageCommandLineAction not found.
java.lang.IllegalArgumentException: Commandline action com.nomagic.magicdraw.twcusageupdater.UpdateProjectUsageCommandLineAction not found.
    at com.nomagic.magicdraw.commandline.CommandLineActionLauncher.newActionExecutor(CommandLineActionLauncher.java:77) ~[core-2024.3.0-55-260588bf.jar:?]
    at com.nomagic.magicdraw.commandline.CommandLineActionLauncher.main(CommandLineActionLauncher.java:42) [core-2024.3.0-55-260588bf.jar:?]
I have done extensive searching and debugging trying to resolve the problem to no avail. Any help or suggestions would be greatly appreciated.
- Gregory Wright
