We're thrilled to share the latest updates and enhancements to the GEOVIA 3DEXPERIENCE roles! These improvements are designed to enhance usability, performance, and overall value for our users. Stay tuned for more details, including new feature highlights.
GEOVIA Earth Engineering Coordinator
Key Enhancements:
✅ Single Source of Truth – Centralize all geoscience data attributes, including Block Models and Boreholes, within secure cloud storage.
✅ Improved Accuracy & Simpler Workflows – Reduce errors and streamline processes with an integrated block model and terrain georeferencing tool.
GEOVIA Geology Modeler
✅ Higher Geological Model Accuracy – Improve model precision by integrating explicit modeling tools directly into implicit modeling workflows.
✅ More Reliable Models in Sparse Data Zones – Strengthen interpretations in areas with limited sampling by enabling users to define overarching geological trends.
User Experience Value
✅ Simplified Interval Classification – Greatly improve usability by streamlining the rules used to classify interpreted intervals.
✅ Faster, Smoother Visualization – Save time during display refreshes with automatic restoration of previous view settings in the Geoscience Interpretation app.
✅ More Flexible Modeling – Enable geology modeling operations using fault models built solely from imported faults.
✅ Clearer Geological Visualization – Enhance clarity by allowing overrides of user-defined display preferences for measurements and data views.
✅ Consistent Cross-App Experience – Deliver a unified workflow by centralizing user preferences across all geoscience web applications.
✅ Stronger Confidence in Results – Help users trust modeling outputs by revealing the borehole intersections used to generate fault surfaces.
GEOVIA Pit Optimizer
✅ Clearer Reporting Periods – Improved period management makes it easy to identify reporting ranges using actual dates.
✅ Stronger Analysis & Decision Making – New material flow reporting and period limit compliance reports provide deeper insights to support operational decisions.
✅ More Intuitive Scenario Insights – A greatly improved experience thanks to clearly defined scenario KPIs and simplified number formatting in limit dialogs.
✅ Reduced Errors & Smoother Workflows – Streamlined processes supported by integrated block model and terrain georeferencing tools.
GEOVIA Strategic Mine Planner
✅ Clearer Reporting Period Management – Improved handling of reporting periods enables easy identification of ranges using real dates.
✅ Deeper Operational Insights – New material flow reporting and period limit compliance reports strengthen analysis and support better decision making.
✅ More Intuitive Scenario Evaluation – A cleaner experience through clearly defined scenario KPIs and simplified number formatting in limit dialogs.
✅ Reduced Errors & Smoother Processes – Streamlined workflows supported by integrated block model and terrain georeferencing tools.
GEOVIA Surface Mine Designer
✅ Design-Driven Stockpile Management – Ensure waste stockpiles meet mine requirements by linking total volumes directly to the design process.
✅ Location-Based Ramp Parameters – Adapt ramp generation to local constraints by varying parameters depending on the area.
✅ More Practical Ramp Designs – Improve ramp usability and accuracy by accounting for flat terrain zones during design.
✅ Scenario-Ready Haulage Networks – Empower mine designers to build haulage networks that support robust scenario analysis.
GEOVIA Underground Mine Designer
✅ Accurate Underground Infrastructure Modeling – Enable mine designers to construct voids that represent underground infrastructure, supporting safer, more efficient and cost-effective mining operations.
✅ Faster Underground Design Workflows – Boost productivity with tools that automatically generate multiple headings along a line.
